por 15 - Page 2 - JeepForum.com
post #16 of 26 Old 04-30-2013, 07:32 AM
bkeese
1949 CJ3A
I bought a cheap undercoating kit from JC Whitney and used it to apply POR15 inside the frame using the wands. I also top coated the exterior of the frame with Plum Crazy Purple about 45 minutes after spaying POR 15. You must do this while the POR 15 is tacky. Now the purple is as tough as the POR 15. Great stuff, except for the UV issue.
1985 CJ7 - total customization underway, Sublime green and Plum crazy purple, Ford 9", 258 w/ Holley 475
1985,93 CJ7,YJ - L98 TPI Vette motor, Atlas twin stick, Dana 60s front and rear, Arbs, 39.5 Swampers
bkeese is offline
post #17 of 26 Old 04-30-2013, 11:10 AM
Taking2long
I just used a wire brush wheel on cordless drill. Pressure washed the under neath first with some degreaser. Went crazy with wire wheel, alternating batteries, took a while. Then sprayed entire underneath with it. Brushed on the parts that the gun couldn't get. Used a whole gallon on bottom and top of tub, interior part not exterior. Been 3 years and I am happy.
Taking2long is offline
post #18 of 26 Old 05-03-2013, 06:44 AM Thread Starter
dustindoughty1
1974 CJ5
the cans of por says use the silver first so i got the silver on and ended up falling asleep (at night after i got off of work ) and didn't get the black por on so i think now i have to wet sand knock off the shinny an then go back with the black so we will see how it goes.
dustindoughty1 is offline
post #19 of 26 Old 05-04-2013, 07:11 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I think they have a primer or something to use between coats.. I forget, but I think I read it on the can..
Rick
Cutlass327 is offline
post #20 of 26 Old 05-04-2013, 06:17 PM
Renegade82
1982 CJ7
Yes, either Tie-Cote which is for a spray gun, or they offer their Self Etching primer in a rattle can.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #21 of 26 Old 05-04-2013, 07:35 PM Thread Starter
dustindoughty1
1974 CJ5
well the por is on the floor of the jeep and the kit come with some chassis coat to put on top of the por black so its on their to........ i wanted to see if it was going to be tough like everyone says and hit it with a rock on one of the heat shields and it chipped does this mean I'm going to have problems with it later on
post #22 of 26 Old 05-08-2013, 01:26 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
How long did you let it cure?
Rick
post #23 of 26 Old 05-08-2013, 09:08 AM
Rollbar
1984 CJ8
I let mine sit in the Fla sun for two days. I did not etch or prime between coats-I let sit for 20min (like the bottle reads-if memory serves) and shot the other coat while it was tacky. No peeling etc. Used a red scotch brite pad to ruf the surface, washed, etc etc.
<----Click
<---- Click
Rollbar is offline
post #24 of 26 Old 05-08-2013, 10:54 AM
Renegade82
1982 CJ7
I believe it says to allow 3-5 hours between coats, until it's "finger drag" dry.
Dustin - how big of a rock did you use? I mean, no paint will be 100% chip proof but this stuff seems to be more chip resistant than most paints or even powder coating.
post #25 of 26 Old 05-09-2013, 08:33 PM Thread Starter
dustindoughty1
1974 CJ5
well i didn't use a big rock a small piece maybe half inch at the biggest.. i guess i was expecting more out of the por than what i got i mean i thought it was going to be pretty hard like powder coating but i guess not i had seen videos on you tube about it... where the painted to pipes and hit them against each other dented one pipe with the other and no chipping so .........
post #26 of 26 Old 05-09-2013, 08:36 PM Thread Starter
dustindoughty1
1974 CJ5
i let cure for 24 or so hours ...... Rick
