pops out of first gear - JeepForum.com
post #1 of 9 Old 12-02-2010, 07:07 PM Thread Starter
jeephog7713
1981 CJ5
my t150 pops out of first gear only in four low and when is under a load or you get off the gas real fast its really makin me mad any help would be great
jeephog7713 is offline
post #2 of 9 Old 12-02-2010, 07:30 PM
rob777
1983 CJ7
Prob bad synchros in tranny
rob777 is offline
post #3 of 9 Old 12-02-2010, 07:32 PM Thread Starter
jeephog7713
1981 CJ5
fresh rebuild all new bearing and syncros
post #4 of 9 Old 12-02-2010, 07:34 PM Thread Starter
jeephog7713
1981 CJ5
would bad motor and trans mounts do it as in the motor twisting to much
post #5 of 9 Old 12-02-2010, 08:16 PM
rob777
1983 CJ7
I guess it could be something to do with it. Probably would be the transfer mount vs motor mount. If you still have leaf springs, check the tightness of rear ubolts as well, you could get slop there too. If they get real loose you start breaking u joints, yoke, or drive shaft binds. Might be an early sign. Another thing I always check after a good run is tranny/transfer case bolts. They can work their way loose and seperate some. Maybe they were not all put in tight enough after your rebuild.
If it's not any of that, well, then not all rebuilds come out as planned and hopefully you have a warranty or an extra weekend to look at it.
rob777 is offline
post #6 of 9 Old 12-02-2010, 08:27 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Body lifts also have a tendency to give transmission trouble if the body comes in contact with the shifter when wheeling.
jeepdaddy2000 is offline
post #7 of 9 Old 12-02-2010, 08:30 PM Thread Starter
jeephog7713
1981 CJ5
The body is clear from the shirred I'm going to go over as much as I can this weekend so any ideas will be great
post #8 of 9 Old 12-03-2010, 05:19 AM
jeepdaddy2000
1971 CJ5
This situation usually comes from the input/mainshaft moving, shift fork not fully engaging the gear, engagement collar installed backwards, or possibly a loose bull gear.
Bad pilot bushing, bad/wrong output bearing, a bad/wrong/missing snap ring, worn/loose shift fork.
You may want to pull the floorboards, shift into first, then carefully pop the trans lid and observe the placement of the first gear, check for any mainshaft movement, as well as inspect the shift fork for problems.
post #9 of 9 Old 12-03-2010, 05:46 PM
white_2003
1972 CJ5
sounds like a work out engagement dog on a slider gear
white_2003 is offline
1st gear Pops Out Krackalacka Jeep CJ Forum 2 06-12-2009 11:07 AM
Ford SR-4 Tranny pops out of gear in CJ7 summitunlimited Jeep CJ Forum 0 05-19-2009 05:16 PM
T-case pops out of gear c17load83 Jeep CJ Forum 4 05-21-2007 11:59 AM
T-176 Pops out of 3rd gear zslnk Jeep CJ Forum 6 05-06-2005 05:22 PM
85 CJ-7 pops out of gear guachinango Jeep CJ Forum 7 03-17-2005 05:17 PM
