Popping sound from driver rear wheel/axle - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Popping sound from driver rear wheel/axle
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Solution to Radius Arm Bind - Meet Lock-N-LoadFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 06-27-2011, 04:18 PM   #1
Blue84JeepCJ7
Hi guys, I keep hearing a popping sound coming from my driver rear axle. I do not know what it is and can't seem to find the culprit.
What I did find was a bad brake cylinder with wet brake pads. Looks like I have a one piece axle kit installed in my AMC 20. The flange has play in it. It will move in and out 1/16 of an inch with up and down play at 1/32 of on inch. Looking at the seal, held in with a retainer plate and four bolts, it could be grease oozing out instead of brake fluid. I did run low on brake fluid the other day and filled up the rear reservoir. I did jack up the passanger side and it too has the same play in the axle.
Anyhow, got a few things to fix but still dont know why I keep hearing popping noises. Worse in reverse. Could both bearings be going bad? Roaring of the tires makes it bad to hear or feel any vibrations.
84 CJ-7
Chevy 350, Mild Cam. (325hp)
Summit (600 CFM) Carb.
1987 TH700R4 "K" Case
32x11.5x15 Cooper ATs
3" Body Lift
Be-Cool Radiator
Black Magic 175 Cooling Fan
Blue Jeep Club Member #212
Blue84JeepCJ7 is offline   Reply With Quote Quick reply to this message
Unread 06-27-2011, 04:24 PM   #2
Skerr
Skerr's Avatar
I have pretty much the same setup that you have, but it is very recent with little use so far. While "joy riding" down the road I had the same symptoms... popping and clicking. When I removed the rear wheel I found my brake job had failed on that side. The flat "spreader" bar that connects between the shoes had fallen out of position, allowing the auto-adjuster to also fall out of place. Fixed it up I was good to go. Hopefully, you will find something in the brakes to "ease your pain"!
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 06-27-2011, 05:54 PM   #3
Rollbar
1984 CJ8
Check the rear end fluid while it is level, bet it's low w/the oil all over the shoes. I will also bet (if the bearings aren't that gone by now) if you fill it up w/fluid it will stop until the fluid gets low and the bearings get hot.
Ask me how I know
Project CJ8 Build Gallery <----Click
CJ8 Build Thread<---- Click
Rollbar is offline   Reply With Quote Quick reply to this message
Unread 06-27-2011, 06:10 PM   #4
Blue84JeepCJ7
Thanks guys, it does "pop" when cold such as backing out of my garage. If it puts me in the ditch before I get it fixed, I'll let ya know ;-)
84 CJ-7
3" Body Lift
Be-Cool Radiator
Unread 06-27-2011, 06:11 PM   #5
Trapshooter
Pretty easy to tell the difference between 90wt and brake fluid.
No matter what, you have a brake job to do once you repair the leak.
Good Luck.............
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build: [url]http://www.jeepforum.com/forum/f8/trapshooters-401-build-1338277/[/url]
Trapshooter is offline   Reply With Quote Quick reply to this message
Unread 06-27-2011, 06:40 PM   #6
Blue84JeepCJ7
Yeah its brake fluid. Not even dripping on the ground.
84 CJ-7
3" Body Lift
Be-Cool Radiator
Unread 06-27-2011, 07:20 PM   #7
Rick7
I had an '84 CJ7 which made a popping sound every so often from the rear model AMC 20 axle. Couldn't figure it out after a whole lot of looking. Later, I found the tube from from one of the axles would shift inside the 3rd member housing every so often. Those tubes are pressed in and not welded and apparently the pressing loosened up. drilled a couply of extra holes into the housing and used the holes to weld the axle tube properly to the housing.
Rick7 is offline   Reply With Quote Quick reply to this message
Unread 06-27-2011, 07:42 PM   #8
BagusJeep
BagusJeep's Avatar
1981 CJ7
Those brake linings look a bit iffy as well. Maybe it is the angle but they look to be debonding. The popping sound may be the brake parts moving inside the drum as they are worn out or may be a consequence of the drum moving around with the play in the hub.
Sounds like you have enough movement to warrant new wheel bearings and seals but whilst there you may as well rebuild the brakes with all new parts, cylinder, shoes, adjusters, minor parts etc. Apart from installing the wheel bearing not a difficult job and you will improve reliability. Jeep parts are not expensive.
BagusJeep is offline   Reply With Quote Quick reply to this message
Unread 06-27-2011, 08:28 PM   #9
Blue84JeepCJ7
Yeap, gonna be a long 4th weekend!
84 CJ-7
3" Body Lift
Be-Cool Radiator
Unread 06-27-2011, 08:57 PM   #10
BagusJeep
BagusJeep's Avatar
1981 CJ7
Happy 4th of July, much more healthy than a barbeque and beer
Unread 07-01-2011, 06:46 AM   #11
Blue84JeepCJ7
Brakes are fixed. All new hardware. The popping was from the brakes being applied, the brake line collapsing and not allowing the fluid to completely release, causing the brake pads to grab the drum and twist. I'm sure there may be more but that's about it from me!
Also I changed out the axle bearings. Another $200+ but figured I better do it.
84 CJ-7
3" Body Lift
Be-Cool Radiator
Unread 07-01-2011, 04:49 PM   #12
Blue84JeepCJ7
Yeap, brakes and axle bearings!
$600 plus two and a half days missed work.
84 CJ-7
3" Body Lift
Be-Cool Radiator
