Polyurethane Gas Tanks - JeepForum.com
post #1 of 15 Old 01-02-2006, 07:19 PM Thread Starter
Workethic
Has anyone seen these? They make them in 20 gallon versions, and they will never rust.
CJ7 1979 4.3l 1997 vortec V6, Endelbrock 4 barrel carberator and intake manifold, Flo Core waterpump, powermaster alternator, Mallory distributor and fuel pump, headman headers, flowmaster dual mufflers T18A tranny, Dana 20 T-case, 15 Mickey Thompson Rims, 33 by 12.5 Super Swampers, Warn Premium Locking hubs, Rancho 9000 shocks, 4" suspension 3" body lift by Skyjacker, Autometer Z gauges, smittybuilt front and rear bumpers, Tom Woods CV joint rear driveshaft.
Workethic is offline
post #2 of 15 Old 01-02-2006, 09:09 PM
knifeboy2
They're not new, what's your point or question?
"If stupidity got us into this mess, why can't it get us out?" -Will Rogers
knifeboy2 is offline
post #3 of 15 Old 01-02-2006, 10:24 PM Thread Starter
Workethic
Are they any good? I have a small 10 gallon tank.
post #4 of 15 Old 01-02-2006, 10:37 PM
jeepskate
It's a gas tank...not much you can screw up there.
Factory tanks only came in 15 gallon steel and 20/21 gallon plastic...you don't have a 10 gallon tank unless someone put something else under there.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #5 of 15 Old 01-03-2006, 08:00 AM Thread Starter
Workethic
I think the previous guy did, because that's all it fills up to.
post #6 of 15 Old 12-11-2009, 10:31 AM
m2rtin
Do the poly tanks have the same measurements as the steel ones? Is the filling neck the same diameter? No issues as these at all?
Thanks
m2rtin is offline
post #7 of 15 Old 12-11-2009, 10:53 AM
SecretSquirrel
1980 CJ7
After I installed my new 15 gallon replacement tank I towed my CJ 7 to the gas station. No matter how hard I tried I could not get over 13 gallons in it.
SecretSquirrel is offline
post #8 of 15 Old 12-11-2009, 11:22 AM
h2ojeep
1978 CJ7
I exchange the OEM steel tank (15 gal) for a 20 gal Poly tank.
There are different tanks for different model depending on what you want to do and what you have, they have kits for most popular swaps.
I got mine direct from MTS, I thank they sale to other outlets. MTS COMPANY, L.C. - Jeep fuel tanks
In my kit, I used the OEM skid plate, and it came with extensions, and the tank was complete with the dip tube, return line, fittings for the roll over connections, and fuel sending unit.
It was an easy swap, with some fab work.
The poly will not rust. I am pleased that I did the change. While I was there I replaced all my lines and beefed up my ground wire. Re assembled all the electrical connections with liberal amounts of dielectric grease.
I have had some fuel delivery issues, but none related to the poly tank.
I put in the 20 gal tank, but I can hold 23 gal.
The dip tube that comes with the kit does not have a filter (sock) on the end, that is probably my only issue.
To fix an unrelated problem, i installed an intank fuel pump, and at that time put in a sock.
I am pleased with my poly tank and I am glad that I made the change.
h2ojeep is offline
post #9 of 15 Old 12-11-2009, 11:42 AM
chet44
Did you actually run it completely out of gas and then fill it up? When I first bought mine and drove it home, the gauge would register full to empty, at which point I would stop for gas, and put approximately 10 gallons in it. I thought the same thing as you until I pulled the gas tank out to replace my rear crossmember and discovered it was a 15 gallon tank with a bad sending unit.
chet44 is offline
post #10 of 15 Old 12-11-2009, 12:02 PM
h2ojeep
1978 CJ7
Additional information
There is an active/ongoing thread about the poly tank.
There are some photos, etc, One photo shows the 0051 tank, (15 gal) I think from Quadratic, I have the similar (from that angle, looks the same) tank from MTS that is the 0051XL and a 20 gal tank.
http://www.jeepforum.com/forum/f8/no...s-tank-921565/
h2ojeep is offline
post #11 of 15 Old 12-11-2009, 12:16 PM
BioTex
1979 CJ7
Mine does exactly the same thing. It would go to empty, and so I'd fill up. 10 to 11 gal. every time. Was out wheeling with H2oJeep, and decided to see how far it would go on "empty". Since he carried the extra gas, I was safe to experiment. Sure enough, I made it back to camp and then some. Must be a common problem.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #12 of 15 Old 12-11-2009, 12:22 PM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
If I may interupt, has anyone ever considered modifying a plastic 97+ XJ tank? It's 20 gallons. Plus they're probably really cheap right now.
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
post #13 of 15 Old 12-11-2009, 01:57 PM
Area.3.Fiftyone
Most likely they will not fit between the frame rails. AFAIK: XJ's are much wider and I doubt the fill holes would be in the correct position.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #14 of 15 Old 12-12-2009, 01:32 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
H2ojeep - how much did you pay? I just can't see paying so much more for 6 more gallons. I have a 6 gallon gas can I can carry cheaper than $120 for the bigger tank and installation kit.
Rick
Cutlass327 is offline
post #15 of 15 Old 12-13-2009, 05:11 PM
h2ojeep
1978 CJ7
Below is a response I gave about a week ago enforcing Romain's comments to someone seeking advise to the increased fuel capacity:
It was post #7, http://www.jeepforum.com/forum/f8/cj...decide-918032/
That post show here in blue;
Originally Posted by Mike Romain
I would really miss being able to run for 350 highway miles before getting gas, especially as I wheel for more than a week back in the bush lots. Having to come out for fuel kills most of a day.
I wouldn't go smaller.
X2
But then it depends on "why" you have your jeep, I like my jeep because it is analogous with "away from civilization ", "roadless", wilderness, isolated etc. where there are no places to get fuel.
And a jeep is not a Prius (thank God), so fuel economy is not likely to be stellar. With that in mind, I like all the fuel I can have.
I made the change from 15 to 20 (23 actual) and to poly. And it was a definite improvement. I though I would be dragging my fuel tank skid, but have not as yet and have been on some challenging trails.
Maybe unique to me (but not uncommon in western states), I live where, after you hit pavement, one can go 70-80 miles with out a place to get fuel. (and as the industry goes, there will probably be fewer and fewer fuel stops)
As noted, if you are using your jeep to run around or to the edge of town, then the smaller tank may be ok, but not the norm for what a jeep is normally used for.
I would try to stay with the larger tank.
Cutless, to answer your question, my cost to purchase the higher capacity tank was about $250 (did it over a year ago and don’t recall the actual amount). You reference $120 difference, I don’t know and never considered.
For the reasons noted from the previous post and the fact that:
1. I don’t have to carry extra fuel inside on the rough roads that the jeep is subject to, that it is not sloshing around, leaking and smelling bad, getting hot and expanding and leaking, taking up extra space, and is a enormous safety hazard.
2. While I could fabricate racks to hold jerry cans to the back (and add the cost of the cans and fab cost, and the difference is now down to about $60). Those tanks would be exposed and unsecured. I am often times away from my jeep for hours, fly fishing, boating, hunting, scuba diving, spelunking, or just sight seeing. Anyone could take or empty my extra fuel supply.
So now the difference is down to $60 more or less (probably less and the difference a lot more that $120 to purchase the gas can and racks as opposed to homemade).
And to reinforce what Mike Romain said, I would not want to be killing time to run back to pavement to refuel. That would be an enormous pain in the "south end".
YES……in weighting the pros and cons, and considering my jeep usage, it is every bit worth the $30, 40, 60, even 120 dollar difference.
Now I grant you that if someone's usage is to ONLY run their jeep to the edge of town, or to run around town with the top town, or their jeep is something to polish, shine, or put chrome on (all good uses for the jeep if it’s their thing) then the extra fuel capacity may not be worth it. I have a jeep friend who lives close to a kid who has “well to do parents”. The kid has a jeep that is equipped with everything, I mean EVERYTHING. We jokingly commented that he must have called Quadrac and said "send everything that fits my jeep, including decals, here is my mom’s credit card ", and the conclusion to the comment was that if it “rings his bell” then we are more that happy for him.
Thanks for the question, in re-evaluating the decision, for my priorities, I feel like changing to the larger fuel tank is a exceptional good judgment.
h2ojeep is offline
Aftermarket gas tanks? Grewe02 Jeep CJ Forum 17 01-14-2015 03:10 PM
fuel tanks vtjeeps Jeep CJ Forum 0 11-21-2007 04:50 PM
What tanks fit a 69 CJ5? 69cj5 Jeep CJ Forum 1 05-12-2007 03:07 PM
Fuel Tanks glaudde Jeep CJ Forum 2 09-11-2004 01:51 PM
Dual Gas tanks on a CJ7 CJman77 Jeep CJ Forum 12 01-31-2004 07:21 PM
