polly gas tank - JeepForum.com
post #1 of 6 Old 02-17-2008, 10:41 AM Thread Starter
pushrod
polly gas tank
the tank in my 86 cj7 is rusted and leaking, i found a polly tank that the guy said came out of a 86 cj7 but it is much bigger than mine, if there both the same year cj why the difference, and what do i need to make it fit in my jeep, or i should ask if it will even fit, i hope it will becaus i bought it,, i would appreciate any help,,
pushrod is offline
post #2 of 6 Old 02-17-2008, 11:16 AM
high51977
sounds like the poly tank is an oversized (20 or more gallons) replacement. you will need the larger skid to install it
Play by the rules you're gonna miss all the fun
high51977 is offline
post #3 of 6 Old 02-17-2008, 11:19 AM
petey156
mine has two 4 inch skid plate extensions. they go between the frame and the skid plate..
petey156 is offline
post #4 of 6 Old 02-17-2008, 11:42 AM
Mike Romain
I have the stock 20 gallon poly tank in my 86 CJ7, it is just the larger option and uses it's own skid plate box. They are useless without the skid plate. It is a box to protect the plastic sides also.
You will need the 20 gallon sender too.
I recently got lucky and got a new tank and skid (my skid rusted away) for $25.00 to go along with the frame I was buying from the same gent.
Mike
Mike Romain is offline
post #5 of 6 Old 02-17-2008, 11:44 AM
cj71983
1983 CJ7
They put 20 gal poly tanks in some CJ's between 82or 83 and 86. I have an '83 and Found out that I had a poly tank when my factory skid plate rusted through. The only problem is finding a skid plate for the tank. The only one I could find was made by kilby. It was like $260 but it was made out of 3/16". I had some sheetmetal laying around and had a local guy bend one for me. All I had to do was drill a few holes and she went right in. You may have to get a different sending unit also because your CJ probably had the 15 gal. tank.
cj71983 is offline
post #6 of 6 Old 02-17-2008, 11:52 AM Thread Starter
pushrod
thank you all verry much,,,
pushrod is offline
Aero Tank 26 gallon gas tank?? texashighridin Jeep CJ Forum 10 10-04-2009 02:05 PM
Tank is full, fuel gauge reads Half tank!?! martyweir Jeep CJ Forum 10 09-25-2008 07:55 AM
CO2 Tank CJhollic Jeep CJ Forum 2 03-16-2008 11:01 AM
Polly or rubber firecord Jeep CJ Forum 2 07-04-2005 09:39 AM
gas tank wilf Jeep CJ Forum 8 12-02-2004 11:53 AM
