-   -   Poll: Worst CJ of the Month June 2011 (http://www.jeepforum.com/forum/f8/poll-worst-cj-month-june-2011-a-1217932/)
danheit 05-23-2011 04:41 AM
If your CJ didn't make the list, it is most likely that I didn't have a spec sheet on it. Put it together for next month, and let's see how you do!
June 2011 - Good Luck Guys!
Originally Posted by lucdog (Post 11575670)
Cool, I'll start.
1984, Renegade
258, nuttered, teamrushed, reworked BBD. GM Ign modual
Dana 300
Amc20
Dana 30
2.72 open
T4
200,581 miles
My daily driver for the last 1.5 years
Stock suspension.
Bill
http://www.jeepforum.com/forum/attac...520_143951.jpg
Can't cut and paste from my phone
Originally Posted by jeepwhore (Post 11575677)
I have 2 submissions, hopefully when I'm finished combining them I can enter that "other" contest. :D
Number 1 Specs:
Year of CJ: 1986
Engine: 4.2L (removed)
Transmission: T-176 (removed)
Transfer Case: D300 (removed)
Front Axle: D30 (removed)
Rear Axle: M20 (pooched....and removed)
Suspension: stock (removed)
Tires: Three 30x9.5 kumho powergaurds and 1 Michelin LTX (removed)
Additional Mods: custom body lines :D
http://i5.photobucket.com/albums/y17...d/DSC00050.jpg
http://i5.photobucket.com/albums/y17...d/DSC00051.jpg
Who knew you could fit that much jeep in the bed of a short box pickup? :D
And Number 2 Specs:
Year of CJ: 1984
Engine: 4.2L (massive blow by)
Transmission: T-176 (blown synchros)
Transfer Case: D300
Front Axle: D30
Rear Axle: M20 w/ 1 pc shafts
Suspension: 4" BDS
Tires: 35x12.50 X-Terrains
Additional Mods: Winch
http://i5.photobucket.com/albums/y17...uild/jeep3.jpg
http://i5.photobucket.com/albums/y17...uild/jeep4.jpg
Originally Posted by amcjeepman (Post 11578926)
Love It! I'll play
Year of CJ
titled as an '81, assembled from several different years
Engine
amc360
Transmission
T177
Transfer Case
D300 4to1
Front Axle
Waggy NT Dana 44, 4.56 Lock rite
Rear Axle
CJ WT M20, trussed smoothed, 4.56s spool, warn Full Float kkit
Suspension
Spring over, Waggy & Wranler leafs
Tires
36" IROKs
Additional Mods
Sawzall, Plasma, Booger Welds & Booty Fab, Warn 8274
http://i168.photobucket.com/albums/u...Aug2010028.jpg
http://i168.photobucket.com/albums/u...Aug2010026.jpg
Originally Posted by FLynes (Post 11579042)
Specs
1976 CJ-5
258
T-150
Dana 20
Dana 30
AMC 20
4" lift
35x12.50
4" body lift
It's ugly, it wobbles, not all the wheels match, it's got rust holes, the tailgate is missing, the front driveshaft is disconnected and strapped to the frame, because the Dana 30 is busted, the steering column and wheel is from a '93 XJ, God knows what the seats are out of, the PO painted driveline parts neon green and yellow and it smells like cat pee.
http://www.jeepforum.com/forum/attac...6-cj-5-001.jpg
Fred
Originally Posted by Three J (Post 11579086)
Specs
Year of CJ 1985
Engine 6
Transmission 5 speed
Transfer Case d 300
Front Axle d30
Rear Axle amc20
Suspension Stock
Tires 20+ year old courser
Additional Mods none yet
http://i50.photobucket.com/albums/f3.../jeepstuck.jpg
Originally Posted by Matt_G (Post 11579123)
Specs
Year of CJ:1979 cj5
Engine:4.2 I6
Transmission:T150
Transfer Case:D300
Front Axle:D30
Rear Axle:AMC20
Suspension:stock
Tires:BFG A/T
what it looked like when i brought it home
http://i621.photobucket.com/albums/t...CJ5/CJ5011.jpg
Originally Posted by spottedfrog (Post 11585829)
When I got it:
1980 CJ5
No axles
Was a 4 cylinder no motor mounted
258 in the back
T176/7 in the back with NP full time 4wd T case in the back
Cut shackles
Manual steering
Not running
http://i328.photobucket.com/albums/l...P/DSCF2704.jpg
http://i328.photobucket.com/albums/l...P/DSCF2689.jpg
Course now I'm here:
Still not running
has T150 trans, Will replace with the T176/7
and Dana 20 T case, Will replace with Dana 300
Dana 30 front axle
AMC 20 rear
2.5 lift springs
1/2" lift shackles
31x10.5-15 tires
258 engine
http://i328.photobucket.com/albums/l...annonimous.jpg
http://i328.photobucket.com/albums/l...P/DSCF3402.jpg
http://i328.photobucket.com/albums/l...P/DSCF3432.jpg
http://i328.photobucket.com/albums/l...P/DSCF3414.jpg
Originally Posted by brian613 (Post 11583590)
Specs
Year of CJ: 1977 cj5 renegade levi
Engine: amc 304
Transmission: Np 435
Transfer Case: twin sticked dana 20
Front Axle: none (getting regeared)
Rear Axle: scout 44
Suspension:Yj leafs spring over
Tires: currently 31x 10.50 15
Additional Mods: swapping in scout 44 up front 4.88 gears grizzly lockers front and rear bedlinned inside of tub
it dose run but cant drive due to no front axle the white one in the last pic is before i removed the front axle
http://www.jeepforum.com/forum/attac...ion-myjeep.jpg
http://www.jeepforum.com/forum/attac...7-17.46.02.jpg
Originally Posted by hotrodzgarage (Post 11585233)
Specs
Year of CJ 1985
Engine 2003 Avalanche 5.3L
Transmission 1976 TH350
Transfer Case 1976 NP205
Front Axle 1976 Blazer D44 Lock rite Locker 4.10
Rear Axle 1979 Bronco 9 inch Spool 4.10
Suspension BDS 2.5 Lift SOA
Tires Swampers 38x14.5x15's
Additional Mods 12.5 lb Winch, Roll Cage......
Before
http://i168.photobucket.com/albums/u...100_1039-2.jpg
Now
http://i168.photobucket.com/albums/u...-07_133411.jpg
littlebuddie 05-23-2011 09:19 AM
All CJ's are beautiful creatures, we should not demean their state of ill health or overlook their potential.
brian613 05-23-2011 02:45 PM
were not demeaning there state of ill health were simply comparing the naturally occurring strategically placed drain holes
hotrodzgarage 05-23-2011 05:15 PM
feewww I'm kinda glad I lost this one. lol:laugh:
mtbtweety 05-23-2011 05:22 PM
Fred had it at "cat pee"
SKT 05-23-2011 09:17 PM
My vote goes to the Daily Driver for the past 1.5 years.
All these "before" pics don't carry the same weight as someone DD'n a crusty CJ IMO.
A lot of props to you LucDog!
lucdog 05-23-2011 09:49 PM
SKT, that's why I voted for mine. Flynn's is way worse looking.
Bill
BagusJeep 05-23-2011 09:50 PM
Flynes cat pee smelling heap takes my vote. The others are all rebuildable but smelling of cat pee? I wouldn't know where to start on that mod.
Some of these are actually pretty interesting. I like the bog standard but tired and rusty Renegade from Three J, i would buy it in a heart beat. A bit of welding, a bit of paint, a bit of lube, a bit if trim and who knows, it could be another top of the line vehicle in Bali for surfers to drool over.
MoC 05-23-2011 10:35 PM
Since we already have a best of the month, and now a worst of the month you should also start a in between of the month........:rolleyes:
John Strenk 05-24-2011 03:38 AM
603 Attachment(s)
Or how about, strangest use of a CJ...
lucdog 05-24-2011 08:36 PM
Not the strangest, but certinly unique. a CJ3b pto driven icecream maker. http://www.mijc.org/category/projects/pto-ice-cream-maker
picture- http://www.mijc.org/wp/wp-content/up...t-MIJC-016.JPG
Bill
kakai81 05-25-2011 02:20 AM
That guy who always posts in the CJotM thread with his busted CJ, primer paint, 37" tires (I think), and no engine, should post here next month. I expected to see him here and he never showed up. That's the only one I would have voted for before Fred.
Memphis5-0 05-25-2011 07:06 AM
Do you have to say anything other than "smells like cat pee"? I think not.
danheit 05-25-2011 03:41 PM
I think we have a pretty clear winner. HOWEVER, it ain't over for 5 more days, so anything could happen!
danheit 05-30-2011 03:26 AM
Alright folks, one more hour left!
The time now is 03:16 PM.
