PoisonBanana - My no tools, budget or clue frame-off. - Page 18 - JeepForum.com
post #256 of 299 Old 11-08-2013, 04:42 PM
lucdog
1980 CJ5
Originally Posted by Kastraelie
Ok then there is still hope! I have like 6 in it now tops.
Only thing is that I don't think the pump is working because I took off the cooler hoses and it doesn't shoot out liquid.
Most likely because 2 of those qts. Went to the torque converter. Add 2 qts. Repeat the above procedure, check the fluid level. Add 1 Qt. from there on out.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #257 of 299 Old 11-09-2013, 09:38 AM Thread Starter
Kastraelie
1977 CJ7
Alright, I've put all i can put in...about 8qts. fluid is backed up all the way up my fill tube and won't go down. Ran it for about 10 mins shifting through the gears.
Still no fluid out the coolant ports.
Is there a way to prime it when the tranny is installed?
Building out a Jeep is like trying to smother a fire with twenty-dollar bills. You just never have enough at once to put it out...
Kastraelie is offline
post #258 of 299 Old 11-09-2013, 11:02 AM
lucdog
1980 CJ5
That I don't know.
?'s
Did you remove the tranny from the engine?
If so, in what sequence did you put it back together?
Basically did you bolt the converter to the flexplate first, and then Bolt the tranny on ( this is the wrong way).
Looks like google may be your friend .
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #259 of 299 Old 11-10-2013, 01:43 PM
JMcDonaldKnives
1980 CJ7
And did you prefill the torque converter with 2 quarts of ATF before bolting it all in? If not then there might already be damage and a few parts will have to be replaced.
Director of Texas Jeeps Corpus Christi Chapter
My Build Threads
1980 CJ7 4.2L T177 D300 D30 AMC20 (under construction)
1989 YJ 4.2L T177 NP231 D30 D35 Pro Comp 3" lift 32/1150/15 BFG AT
JMcDonaldKnives is offline
post #260 of 299 Old 11-10-2013, 06:45 PM
lucdog
1980 CJ5
I'm under the impression the TC doesn't need to be filled prior to install. I will say my knowledge of the TH350 is about zero, however, I do know about the 700r4 and th400. I drained the TC's when they were removed, and didn't refill them before installation didn't have a problem.
This was based on the tranny guy who helped me install a manual valve body in the 400, and rebuilt the R4 with a new converter.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #261 of 299 Old 11-25-2013, 02:44 PM Thread Starter
Kastraelie
1977 CJ7
So going through my worklog...
Yeah, we bolted torque converter to the flexplate, then bolted the tranny to the TC.
I've been looking for a new tranny in the meantime. As Skerr suggested, I have been looking into the 700R4, but price, install, and benefit is holding me back a little.
post #262 of 299 Old 11-25-2013, 07:44 PM
Skerr
Keep looking. Check CL. It will show up. I promise.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #263 of 299 Old 11-29-2013, 11:56 PM Thread Starter
Kastraelie
1977 CJ7
Well I bought a transmission. B&M TH350. I kinda wimped out after I dropped the money and wanted to return it and rebuild my own...doesn't actually look too hard to be honest. Anyways it would cost way to much to return so I am going to roll with it.
Only thing is picking out a Torque Converter has got me all confused. There are so many opinions on the net and I don't know what to listen to...
I'm very easy on my Jeeps, on and off road. I tend to let the motor and gearing do the work by itself and give it very little gas. a 350 chevy is badass motor for a Jeep...but I would be happy with a small 4 banger to be honest...
I'm worried about getting a TC with a stall speed so low that it overpowers my brakes, but I also don't want one that requires me to load up on the RPMs...especially with my big tires and short drive shaft.
I'm also broke...so a $200+ TC is out of the question....
Ideas or suggestions? Opinions?
post #264 of 299 Old 11-30-2013, 08:47 AM
Skerr
Wish I could tell you something, but I know nothing about this stuff. Bill just rebuilt a TH400 and installed it... he can probably tell you. Or maybe swatson454. I can't think of anyone else with autos.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #265 of 299 Old 12-09-2013, 02:09 PM Thread Starter
Kastraelie
1977 CJ7
I'm more stuck than ever on this.
It seems I need to know stuff I can't find out easily -- my current stall speed, my cam specs, and my vehicle weight. I need to start making some educated guesses. xD
post #266 of 299 Old 12-14-2013, 07:18 PM
swatson454
1983 CJ7
I'm REALLY late to this thread and I apologize. You do some class-A work by the way.
Are you able to answer the above questions? Your intended use and how you envision its behavior is probably the most helpful.
Let's worry less about the weight, cam specs, compression, etc. and focus more on what it did before, what engine/gearing/tire changes you've made and how you'd like it to behave now.
This isn't exactly my forte but hopefully I can help.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #267 of 299 Old 12-14-2013, 08:37 PM
Skerr
Hey Shawn. Glad to see you.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #268 of 299 Old 12-14-2013, 09:00 PM
swatson454
1983 CJ7
You only say that because you can't see me. I look like a snake's *ss that's shedding its skin. I would scare your children. No Bueno!
Reminds me of this movie but I don't know why.
You fight so damn hard to keep harmful people out of your life and the SOB is calling from inside the house?
Again, not a clue how it relates to this thread. Perhaps I'm feeling creepy
Shawn
post #269 of 299 Old 12-14-2013, 10:50 PM
xrunndonex
1994 ZJ
Video Link: http://www.youtube.com/watch?v=5d-_Z75Do7c
Shawn
Let me put my tinfoil hate on quick your trying to read my brain waves over the forum
xrunndonex is offline
post #270 of 299 Old 12-21-2013, 03:15 PM Thread Starter
Kastraelie
1977 CJ7
Thanks guys. I kinda just went away on business and just ordered this:
http://www.amazon.com/JEGS-Performan...rque+converter
A couple of my friends just said don't sweat it...get something as close to stock as possible.
Thing is, I didn't see a lot of new, stock spec TCs...
Anyways.
I worked on the Jeep yesterday morning and today for the first time in a while.
The engine had a huge knock, but it was the new distributor. The cap wasn't seated right from the factory. Got that fixed.
Got the new transmission in. I filled the TC with more or less a quart of fluid, then popped it in on the pump--measured and got exactly 1" from the bolt holes on the TC to the bell housing. This is what the manual wanted.
Only hiccup is that there was a 1/4" gap between the TC and the Flex Plate. I was stressed about this but lots of people online say a gap is normal, but there is some dispute on how much is acceptable. 3/16 seems to be the majority vote. I was GOING to put a washer as a spacer in between there but forgot. I've run it since then...hope I didn't destroy it.
The engine oil pan leaks like a SOB from everywhere. Looks like I didn't get it sealed up with silicon as good as before. Hard to see when its installed--dark and oily. Power steering leaks from the input shaft seal, and the transmission leaks from the fill tube. Dangit.
ANYWAYS
So I wanted to see if I could drive the darn thing today. Played with the carb a bit and I'll just ignore it for now. Dave think's it is bad. I don't know yet.
I put 5 quarts of B&M's ultra expensive BS fluid in it and shifted through the gears. It's not engaging. Then I read the instructions a few more times and I think its worded funny but the idea is you put 5 in while running THEN add MORE till its full. The tranny seemed to have fluid in it when I got it--not full by any means but it drained out half a quart after it installed...so I think there was fluid up in there?
I'm not going to panic. I'm going to go shim the torque converter a teeny tiny bit, buy more fluid, and see if I can get the transmission to engage.
If it doesn't I am going to push the Jeep backwards into the Bayou.
Does anyone have any clue what color this is? mcp0526 Jeep CJ Forum 5 04-17-2012 10:32 AM
CJ won't stay running.. no clue! J33P'r Jeep CJ Forum 13 11-04-2011 10:24 PM
1973 DJ5, and i have no clue where to start Spencedaddy Jeep CJ Forum 4 04-21-2009 10:04 AM
NEW Jeeper and dont have a clue where to start Chivo69 Jeep CJ Forum 11 12-13-2008 11:05 PM
no clue on gearing chuckwag Jeep CJ Forum 6 11-11-2007 09:26 AM
