Plug wires for TeamRush - JeepForum.com
post #1 of 7 Old 06-14-2011, 04:58 PM Thread Starter
Donobrew
What plug wires sould you use on a TeamRush upgrade?
Troy
85 CJ7, 258, TeamRush Upgrade with CDI, Nutter Bypass, MC 2150, 3" OME Springs, 33 BFG All-Terrain
Next Project New 1 piece axles for AMC 20 w/ OX Locker
My wife's rig: 2010 FJ Cruiser 4X4, Auto, 3" Lift, Warn Rockers, some TRD stuff
Donobrew is offline
post #2 of 7 Old 06-14-2011, 05:00 PM
CSP
Assuming for a six cylinder, 91-99 Cherokee/Wrangler with the 4.0.
CSP is offline
post #3 of 7 Old 06-14-2011, 05:06 PM
mopar408
1974 CJ5
what does everyone use on a V8?
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline
post #4 of 7 Old 06-14-2011, 05:32 PM
JeepHammer
Running On Empty...
1973 CJ5
There are two or three good 'Cheap' choices for an I-6, but with V-8 you are MUCH better off with a 'Cut To Fit' set of MSD p/n 3119 wires so they actually FIT the engine and work correctly.
I-6 engines are all VERY SHORT, so not a lot of resistance or impedance due to lenght,
But you can't say that about V-8 wires, so a top quality set is the best plan.
I use MSD p/n 3119 wires because they are the best, reasonably priced wires I've found so far.
They come with both sets of boots, long enough to do the job, and they have good instructions, stripping/crimping tool included.
Virtually impervious to heat, chemicals, and conduct more of the spark energy the coil makes to the plugs.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #5 of 7 Old 06-14-2011, 05:40 PM
sanddrag
I'm no expert, but for my 258 I used genuine Motorcraft wires for the Ford 300ci which seem just fine to me. They were cheap from Rock Auto.
sanddrag is offline
post #6 of 7 Old 06-14-2011, 06:16 PM
mopar408
1974 CJ5
FWIW, if you go to Moroso's website and go into their plugwire section and into "custom fit" they have a dialog box at the bottom that is labeled 'buyers guide" that has a chart that lists all their custom sets and shows each wire in the set by length and terminals for both ends, Only bad is it gives their part # on the set and not what it fits. You have to go back and figure what the p/n fits but that only takes a minute. Only one I've seen and handy for buying OTC brands at the FLAPS.
mopar408 is offline
post #7 of 7 Old 06-14-2011, 07:33 PM
keith460
Jeep. There's Only One
keith460's Avatar
I purchased most all my parts for the TeamRush from NAPA and it is posted as a Sticky.
Fit and finish is right and never have problems when using a MSD unit for the ignition system.
1984 CJ-7 Renegade
keith460 is offline
TEAMRUSH Upgrade, Who SELLS PLUG WIRES?? Fjguercio Jeep CJ Forum 14 06-02-2010 09:16 PM
plug wires mxracer919 Jeep CJ Forum 2 03-09-2010 10:24 PM
Teamrush MSD plug wires wm69 Jeep CJ Forum 13 02-07-2010 06:33 PM
Which plug wires fit AMC V-8 w/HEI best? What are you using? hfjeff Jeep CJ Forum 2 04-21-2006 12:36 PM
Where do these two wires plug in? SQF1 Jeep CJ Forum 7 02-14-2006 07:31 AM
