Please Help!! - JeepForum.com
post #1 of 7 Old 12-08-2009, 09:00 PM Thread Starter
Project82CJ
Please Help!!
I have an 82 CJ7 and cannot figure out the wiring schematic for the wiper motor switch. I have the three wire from the motor but the switch has five. What do the other two post's on the switch need and where do they go. I figure its a pos. and a neg. wire but i am not sure. Can someone please help. Its rainy season and i have no wipers!!!!!! HELP me get my wipers going please. Thanks for any advice...
Cameron
Project82CJ is offline
post #2 of 7 Old 12-09-2009, 06:06 AM
Mike Romain
Did these parts ever work together in the past?
There are three flavors of parts that I can think of off hand. An old 3 wire motor and switch, a newer 4 wire motor and switch and a switch and wiper delay module.
Mike
Mike Romain is offline
post #3 of 7 Old 12-09-2009, 01:53 PM Thread Starter
Project82CJ
I have a 3 wire (black,green and red) coming from the wiper motor. I bought a switch that has five terminals. The 3 wire from the wiper motor will hook up to 3 of them but the switch has two terminals left. Is it a power and ground? If so which is which?
Thanks for any help
cam
post #4 of 7 Old 12-10-2009, 06:39 AM
Mike Romain
I can't find the right schematic right now, will keep looking.
As far as I know, you can't mix and match the switches and motors. You need to buy the switch for the motor you are using.
Do you not have the wiring harness? That would sure help to ID what kind of switch is needed, the plugs are different.
Mike
post #5 of 7 Old 12-10-2009, 07:09 AM
Mike Romain
Here you go, found what I was looking for. This thread has the 3 and 4 wire schematics.:
http://www.jeepforum.com/forum/f8/wi...y-long-915241/
Mike
post #6 of 7 Old 12-10-2009, 08:26 AM
John Strenk
John Strenk's Avatar
1976 CJ5
The switch that has 5 terminals on it is correct. 3 for the wiper motor, 1 for the power, and 1 for the washer. Usually washer wire is yellow if I recall correctly and red for power and the wiper motor has a plug that will mate properly.
Interesting to note that if you reverse the power and washer wires on the switch the wipers will only work if you push in on the switch.
Note not every switch is made this way but 3 terminals will have to line up for the plug from the wiper motor.
For Example this is a new switch that everyoone seems to get when they buy a replacement:
John Strenk is offline
post #7 of 7 Old 12-10-2009, 08:58 AM
Mike Romain
There you go, figured John would have it. The ground is the windshield frame. Mine gave up so I added a dedicated ground to a wiper motor bolt.
Mike
