Please help! - JeepForum.com
post #1 of 7 Old 04-25-2002, 10:26 AM Thread Starter
Holiday
Post Please help!
OK,
I have a problem. I had a knock in the rear when i was up/ down shifting2nd to 3rd 3rd to 4th ect ect. I also have some slight vibration while driving.I just had my ring and pinion replaced, as well as all the bearings involved with changing them. There doesnt seem to be any play in my rear driveshaft anymore. I did not replace the ujoints yet. I'm running 4 inches of suspention lift, AMC 360, t-176 4spd, dana 300, AMC 20 with POS 2 piece axles, 33x12.50's. Is it the Ujoints? if so what is a good brand to get? Or is it my POS 2 piece axles?? I dont know how to tell if its the shafts. Hopefully its just the Ujoints. There is no cv joint, or axle shims in the rear. What should I do next? I'm getting tired of spending money on unbroken parts. Ack. Isnt jeeping great? What should I look at next??
I dont think its the trans but i guess it could be??
I forgot to say also that I replaced the transmission mount. When i had someone else drive the jeep, when they shifted the entire rear axle rotated up, then back down, i was told the bad tranny mount made it do that. But i havent been able to verify that the new one fixed that because i havent had someone else drive the jeep so i could look at it. So if its still doing that then maybe that could be causing the clunk. Also, it only clunks once when you engage the gears.
Holiday is offline
post #2 of 7 Old 04-25-2002, 02:18 PM
4wheeler4CJ
4wheeler4CJ's Avatar
Arrow
It sounds like a simple case of U-Joints. Buy some quality ones at a regular auto parts store, ask for the "good" ones, a good store will know what to sell you. (Don't go to Pep Boys, LOL!)
If you changed the tranny mount it should be ok there. There are 2 mounts, one is a torque mount that merely prevents excess torque-movement, make sure that one is good also.
4wheeler4CJ is offline
post #3 of 7 Old 04-25-2002, 06:25 PM
hollywood
Post
The upward rotation of the rear end is know as "axle wrap". It's caused by torque and a leveraging effect on your longer springs. (longer arc due to the lift) The only way to cure it is to attach another link to the axle to keep it from trying to rotate in the opposite direction of the tires. This is, however, counter-productive if you're into the articulation thing. The "clunk" could be the result of the axle comming into contact with something while its dancing around under your rig (muffler, shocks, etc.) It could also be the U-joints as suggested in the previous post. I strongly agree to get "good" ones. I buy a lot of parts from the chain stores, but their U-joints aren't one of their better items. I just got a set of heavy duty servicable ones from NAPA for $15. Good luck finding the noise - watching and listening while someone else drives is probably your best bet.
- Jeff
'83 cj
Another 7 by "CJ's Heaven"
hollywood is offline
post #4 of 7 Old 04-25-2002, 09:19 PM
Hippo393
Post
Which U-joints are the good ones and which ones are the bad ones? I just had a U-joint replaced by the local repair shoppe. How can I tell if it's a goodie or a crappie?
Hippo393 is offline
post #5 of 7 Old 04-26-2002, 05:56 AM Thread Starter
Holiday
Post
Well I figured out the problem. My U-bolts way undetorqued. You could acutally see through the leaves. I was reading how they're supposed to be 100 FT-lb so i got under there and checked them out and they were probably 5 ft-lb! So I tightened them up and now i'm fine. I did pick up some universals to through in there too because there is some slight vibration now. But the knocking is gone.
Holiday is offline
post #6 of 7 Old 04-26-2002, 06:30 AM
4wheeler4CJ
Arrow
Hippo, check with your local NAPA, they'll tell you the good brands. I forgot, I haven't had to do any in a while (because I use good ones! ).
Holiday, congrats on the problem, damn good thing you found that! That could have been catastrphic on the highway! <img border="0" title="" alt="[Eek!]" src="eek.gif" />
post #7 of 7 Old 04-26-2002, 11:02 PM
hollywood
Post
If your local shop did the repairs, you probably got decent joints. Most shops only deal with the reputable parts stores.
As for the U bolts - sometimes just taking a closer look will reveal the problem. I think the proper torque is 80 pounds, but in my opinion more is better than less. I'm glad you figured it out
- Jeff
'83 cj
