please everyone help i need answers quick - JeepForum.com
post #1 of 5 Old 07-20-2007, 08:36 PM Thread Starter
bigflatblack
1988 XJ Cherokee
what kinda transmissions can bolt up to my 1980 amc i6 i have a bell housing that will fit it already...will anything out of like a chevy 4x4 blazer work 80s era...i am trying to get my jeep going and cnt find a t5 or anything around here.... ....and i forgot will a brake booster set up out of a wagoneer work in a cj
bigflatblack is offline
post #2 of 5 Old 07-20-2007, 10:32 PM Thread Starter
bigflatblack
1988 XJ Cherokee
anyone??
post #3 of 5 Old 07-20-2007, 10:34 PM
gosupes
There are a number of tranmissions that will work with the right adapter and some $$. But then you might also need driveline alterations and so on. If you want to go cheap, look for a T4 and change the input shaft if needed. Or a T176 will bolt up, but drivelines will need to be changed. What about swapping in a AX15? It will bolt up with some minor alterations and a clocking ring. Or a NV3550 and so on. It really matter how much you want to spend.
Not sure about the booster.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #4 of 5 Old 07-20-2007, 10:37 PM
high51977
Jeep shares a mounting pattern (where the trans mounts to the bell) with ford and some dodge. A borg warner t-18 would be ideal found in fsj's and ford pickups in the 60's and 70's maybe other eras too. Not sure about the booster
Play by the rules you're gonna miss all the fun
high51977 is offline
post #5 of 5 Old 07-21-2007, 01:00 AM
Seether
Seether's Avatar
Booster
The Wagoneer booster is too big, won't fit.
Seether is offline
Several answers needed on wiring issues. DUX4LIFE Jeep CJ Forum 3 09-12-2009 08:53 AM
1986 CJ7 Questions and Answers wertyu78 Jeep CJ Forum 4 01-11-2009 06:25 PM
Newbie looking for answers Rivcamp Jeep CJ Forum 2 10-27-2006 09:10 PM
Dana 44 - Quick answers needed!!! CJHVN Jeep CJ Forum 9 08-03-2005 08:55 PM
NEW B here. looking for answers. rkm Jeep CJ Forum 2 12-27-2004 11:25 PM
