Please comment on this drive shaft angle - JeepForum.com
post #1 of 12 Old 08-02-2010, 09:56 PM Thread Starter
Splinter
1980 CJ5
I am building a CJ5 on which the PO did a spring over. The geometry of the drive shaft does not look proper. The diff is angled up. I have only driven it around the yard. When backing up there is a terrible shudder. Will a double cardan fix this problem? How does it go onto the drive shaft. Thanks for any info.
Splinter is offline
post #2 of 12 Old 08-02-2010, 10:07 PM
jcal73
jcal73's Avatar
2015 JK Wrangler
Looks like the diff is set up for a double cardian allready.
The double is a complete assembly to replace your shaft.
Look at this link, it has some really good pics and from what I hear they are a good vendor as well
JEEP CV DRIVESHAFT DANA 300 - 20 COVERSION CJ DRIVELINE: eBay Motors (item 250664213092 end time Aug-09-10 08:44:27 PDT)
For a regular set up the joints need to be in the same plain.
Like this
I------I or /--------/ or \---------\
Not like this
/--\ or I---------\ or /------------I
I saw a really good PDF on here a while back from a guy on here called gojeepin PM him and I bet he would email it to you.
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #3 of 12 Old 08-02-2010, 10:18 PM
jcal73
jcal73's Avatar
2015 JK Wrangler
Found the link,
If your jeep has a PO installed springover you need to read this!
http://www.jeepforum.com/forum/f8/ef...in-etc-784807/
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #4 of 12 Old 08-02-2010, 11:16 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
It's double CARDAN, or CV.
That's a fairly steep angle, from the looks of it. Have you put an angle finder on the shaft to see what it is?
Don't know about it being set up for a CV already....for a CV, you want the pinion angle to be a couple degrees less than the shaft angle...that one looks to have more than just a degree or two of difference.
Pacfanweb is offline
post #5 of 12 Old 08-02-2010, 11:55 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
looks like your e brakes are not hooked up.
Mail crawling.
MisfitSeven is offline
post #6 of 12 Old 08-03-2010, 05:50 AM
jcal73
jcal73's Avatar
2015 JK Wrangler
At least I didn't call it a cardigan!
Thanks for the correct spelling.!
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #7 of 12 Old 08-03-2010, 10:06 AM Thread Starter
Splinter
1980 CJ5
Thank you all for the valuable info. Jeff, that link is really helpful.
Splinter is offline
post #8 of 12 Old 08-03-2010, 10:17 AM
Pathkiller
1974 CJ5
It's not that the angle is too steep (it's about par for the course on a CJ5), it's the fact that the angles don't match. The front and rear u-joints need to be running at the same angle. As it is you have maybe a 30 angle in front and maybe 5 in rear. This will cause severe vibration and u-joint failure.
Pathkiller is offline
post #9 of 12 Old 08-03-2010, 01:48 PM
JeepnBlake
Go with the double cardan, You can get an xj front drive shaft for 50 and the junk yard, get it cut down another 50 and then you just need a yoke for the drive shaft. If you can get the yoke too then you don't need to buy one, but if they won't sell it to you, you can get one online fairly inexpensively.
http://www.jeepforum.com/forum/f8/da...-links-894019/
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #10 of 12 Old 08-03-2010, 02:21 PM Thread Starter
Splinter
1980 CJ5
I am wondering why the PO tilted the diff upwards. Had he left it parallel with the frame it would have been much better. Right?? However then it might have been too short??
Splinter is offline
post #11 of 12 Old 08-03-2010, 02:30 PM
Full Tank
1980 CJ5
My guess is the PO was planning on a DC drive shaft.
You have to establish what the PO did to rotate the axle like that.
Are there shims (wedges) between the leaf pack & the spring/shock plate?
Also, are you planning on leaving the Jeep SOA or returning it to SUA?
FT
1980 CJ5 39k
Dana 30--AMC20--D300--T176--258
Dana 30--AMC20--D300--T5--2.5L
Full Tank is offline
post #12 of 12 Old 08-03-2010, 06:34 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
No. Even a stock pinion angle is higher than // to the frame.
You want 1-3 degrees lower than the driveshaft angle, according to most experts.
Whether you need a CV joint or not depends on the angle, but if you need one, they usually want to have almost no pinion angle.
axle , cv shaft , double cardan , driveline angle , driveshaft
Grand Cherokee Drive shaft/CV Shaft jollyroger Jeep CJ Forum 5 12-13-2011 05:31 PM
Drive shaft angle questions on 84 CJ kev12 Jeep CJ Forum 4 07-07-2010 10:09 AM
terrible drive line angle i need to no my options lsch4215 Jeep CJ Forum 4 04-16-2010 10:47 PM
Drive Shaft Angle with 2.5" of lift aqsport196 Jeep CJ Forum 31 04-09-2009 03:32 PM
CJ-5 rear drive-shaft angle/pitch Ol' Roy Jeep CJ Forum 4 06-22-2005 10:51 PM
