Plastic Valve Cover hold down broke - JeepForum.com
post #1 of 11 Old 09-01-2009, 07:36 PM Thread Starter
rcawrse
Hi guys,
One of the black washers that hold down the plastic valve cover on 85 CJ7 4.2L 6 broke off. Any idea where to get a replacement piece? I am assuming it is a washer but could be called something else.
Thanks,
Rob
rcawrse is offline
post #2 of 11 Old 09-01-2009, 07:50 PM
spittoon
the washer broke before the plastic did? thats odd. if you get desperate, i just put on a new plastic cover and have a couple of extra nut/washer combos i could drop in an envelope to you..
spittoon is offline
post #3 of 11 Old 09-02-2009, 01:08 AM
carnuck
1984 J-Series Truck
Or get an aluminum replacement and call it good! (I did mine)
carnuck is offline
post #4 of 11 Old 09-02-2009, 06:24 AM
Mike Romain
I am wondering what part you are looking for...
Do you mean those donut shaped washers that go on the rocker bridge bolts under the valve cover? If so, they come with a new valve cover gasket.
Mike
Mike Romain is offline
post #5 of 11 Old 09-02-2009, 09:27 AM Thread Starter
rcawrse
The washers go on the outside over what I assume is the engine block head bolt to hould down the valve cover.
I have an aluminum valve cover on it already, but have not tapped the two holes on the driver side. Would that be a better way to go?
-Rob
rcawrse is offline
post #6 of 11 Old 09-02-2009, 01:54 PM
Mike Romain
Ah, the big washer that is part of the nut that goes on the head bolt. I think I would just use a thick metal washer the right diameter under the nut instead and be very careful how tight I made it. I think loctite is needed on those, they always back off loose.
Mike
post #7 of 11 Old 09-02-2009, 02:11 PM Thread Starter
rcawrse
I'll give it a shot. Thanks.
rcawrse is offline
post #8 of 11 Old 09-08-2009, 01:36 PM Thread Starter
rcawrse
Turns out when I took off the aluminium valave cover a chunk from the front broke off. I assume this means the bolts were too tight?
rcawrse is offline
post #9 of 11 Old 09-08-2009, 01:40 PM
JoonHoss
2011 JK Wrangler
sounds like it. I would order a new (aluminum) cover, and tap/thread/install it the correct way.
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #10 of 11 Old 09-14-2009, 07:21 PM Thread Starter
rcawrse
any special tool to keep the drill straight when drilling any recommendations? what is the compression and our performance improvement with going to an aluminium valve cover?
The other issue is that the back bolt is basically impossible to get on being so close to the fire wall.
Any thoughts or how have you guys tightened that sucker down?
Thanks,
Rob
rcawrse is offline
post #11 of 11 Old 09-14-2009, 07:27 PM
fish1erp
1982 CJ8
Rob
Hopefully none.
It's purely decorative, but functional by keeping the oil in the upper end of the motor and not down the sides of the block
Full-time Firefighter/Paramedic. IAFF Local 2915
"Chrome don't get you home"
fish1erp is offline
258 plastic valve cover question spittoon Jeep CJ Forum 7 08-26-2009 07:31 AM
Plastic Valve Cover 4.2 BillsFan Jeep CJ Forum 22 07-03-2007 11:53 PM
Valve Cover. Plastic, Aluminum or Steel? White92 Jeep CJ Forum 10 06-23-2007 03:48 AM
Cracked Plastic valve cover replacement?? FIRE UP Jeep CJ Forum 3 01-31-2005 06:24 AM
Replacing Plastic Valve Cover on 81 CJ 258 zor169 Jeep CJ Forum 6 06-18-2003 10:43 PM
