pivot pin broken dana 20 single stick - JeepForum.com
post #1 of 3 Old 05-15-2013, 07:19 AM Thread Starter
cjk5
So i picked up a 74 cj5 that has been setting sence 05. Replaced the motor with a stock 304 2 bbl engine and kept the stock transmission and tc. Swapped the stock axles for a set of k5 blazer axles and ran it until last night. My girlfriend took it out to play and couldnt get the tc to shift to 4low so she kicks it and breaks the pivot bolt, i need to know how to remove the bolt
sent from under my jeep using JeepForum
cjk5 is offline
post #2 of 3 Old 05-15-2013, 12:42 PM
jp360cj
1977 CJ7
Is it the one where the shifter stick connects to the linkage?
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #3 of 3 Old 05-15-2013, 06:57 PM Thread Starter
cjk5
Yes where it connects to the shifter support, it has broken off to a point on the linkage side so there is no way to clamp to it to take it out. And just figured out my k5 front diff had busted also
cjk5 is offline
