pitman arm nut size - JeepForum.com
post #1 of 15 Old 02-21-2008, 11:23 PM Thread Starter
dragracer1199
pitman arm nut size
what is the size of the pitman arm nut on a 78 cj5? looks like 1 1/2 or 1 1/4.
dragracer1199 is offline
post #2 of 15 Old 02-22-2008, 06:44 AM
M79
1979 CJ7
Not sure of the size. But when I pulled mine, I just used an oversized crescent wrench.
Then beat the handle of the wrench with a hammer... came right off.
maybe someone else knows the exact size? (bump.)
M79 is offline
post #3 of 15 Old 02-22-2008, 07:16 AM
cj71983
1983 CJ7
my 83 CJ7 is 1 1/8"
cj71983 is offline
post #4 of 15 Old 02-22-2008, 07:25 AM
John N
1981 CJ8
Every one I've done is 1 5/16",
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #5 of 15 Old 02-22-2008, 09:29 AM
Bard
x's 2 here.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #6 of 15 Old 02-22-2008, 03:06 PM
Patriot6
1982 CJ5
Just replaced the gear box last weekend on my '82 CJ-5, the bolt was 1 5/16" as the others have stated above..
1982 Jeep CJ-5 Renegade
Stock 258 (148k miles), T-176, D300 w/4:1 low
2.5" spring lift, 1" body lift, 33"x12.50" BFG MT's
D30 with Powr-Lok, AMC-20 with Lock-Rite and 1 piece axles, 4.10 gears
Patriot6 is offline
post #7 of 15 Old 02-25-2008, 10:46 PM Thread Starter
dragracer1199
thanks, 1 5/16 it was.
post #8 of 15 Old 02-25-2008, 10:49 PM
John N
1981 CJ8
So, what did I win?
John N
John N is offline
post #9 of 15 Old 10-31-2013, 02:59 PM
hagan39
1981 CJ7
Bump... does anyone know of a good source to actually replace the pitman nut???
Mine is toasted and needs replaced.
hagan39 is offline
post #10 of 15 Old 10-31-2013, 06:33 PM
WSS
WSS's Avatar
1972 CJ5
It is probably a 7/8-14 jam nut, try fastenal
WSS is offline
post #11 of 15 Old 11-01-2013, 09:49 AM
CSP
That's a good place to look.
Just as an FYI, all the sizes mentioned above - 1-1/4", 1-5/16", etc are the sizes for the wrench/socket used to remove the nut. They are not the size to use when looking for a new nut.
CSP is offline
post #12 of 15 Old 11-03-2013, 01:32 PM
jumper182
Junior Member
1980 CJ7
Okay, dumb question, but could a new steering gear box have a different size than a 7/8-14?
I got a re-manufactured Cardone 27-6534 gear box, and new 7/8-14 nut will not go on it. I went back to the local auto store where I bought it, asked them, they pulled one from the shelf, tried a 7/8-14 and it would not work.
Ive looked online, no luck.
The threads look good, all thought I may have rolled the first thread trying to get the nut on, no more than 1/2 a turn.
The diameter of the shaft is .860, which leads me to think its a M22.
Thread count is 14 per inch.
Any suggestions?
Thanks
Mike
jumper182 is offline
post #13 of 15 Old 11-03-2013, 02:02 PM
Spieg8
1984 CJ8
Don't now for sure, but Saginaw did change to metric threads for the hose fittings in 1980, so you may be right about the M22 size on the pitman nut.
Spieg8 is offline
post #14 of 15 Old 11-28-2013, 12:52 PM
jumper182
Junior Member
1980 CJ7
I was able to get it fixed....by filing off the first thread to get to clean straight ones.
I also got this information from the Tech email for Cardone
Here are the specs I have available..............
27-6534 power steering pump for 1980 jeep cj7
*** TYPE: SAGINAW
A): ID MARKS: EF
B): CASTING NUMBER: 5691676
*********** MOUNTING HOLES ************
C): NUMBER OF MOUNTING HOLES: 4
D): MOUNTING HOLE SIZE: 7/16X14
************ PRESSURE PORT ************
E): PRESSURE PORT THREAD SIZE: M18X1.5
F): PORT TYPE(SEAT/O'RING): O-RING
G): CHECK VALVE(YES/NO): YES
************* RETURN PORT *************
H): RETURN PORT THREAD SIZE: M16X1.5
I): PORT TYPE(SEAT/O'RING): O-RING
J): CHECK VALVE(YES/NO): NO
************* INPUT SHAFT **************
K): INPUT SHAFT OD: 0.875 (7/8)
INPUT SHAFT SPLINE OD: 0.800
L): NUMBER OF SPLINES: 31
M): ROTATION:STANDARD
N): NOTCH IN SHAFT(YES/NO): YES
O): GROOVE AROUND SHAFT(YES/NO):NO
P): POSITION OF FLAT @ CENTER: 9 O'CLOCK
Q): NUMBER OF TURNS: 4 1/8 (+/-1/8)
************ PITMAN SHAFT **************
R): THREAD SIZE: 7/8X14
S): NUMBER OF SPLINES: 32+4 BLANK
T): PITMAN SHAFT OD: 1.250
post #15 of 15 Old 11-30-2013, 11:59 PM
WSS
WSS's Avatar
1972 CJ5
Good info, thanks for posting!
The buggered threads can sometimes be chased with a thread file. I carry one on the trails for all those 40yr old bolts we mess with. LOL
WSS
WSS is offline
Pitman arm nut size imtheant Jeep CJ Forum 4 03-24-2009 07:11 AM
Drop Pitman Arm Size, how big? blackbirdxx Jeep CJ Forum 9 03-01-2009 04:38 PM
Pitman arm Bolt size? breceski Jeep CJ Forum 3 07-09-2008 12:44 PM
Post your lift size, tire size, necessary modifications, etc. Hillbillyd Jeep CJ Forum 7 06-06-2004 08:38 PM
Pitman Arm??? jboyd123 Jeep CJ Forum 1 02-21-2004 08:41 PM
