Pitman arm hitting steering arm - JeepForum.com
 6Likes
  • 1 Post By y2k-fxst
  • 1 Post By Spieg8
  • 2 Post By CrashOdle
  • 1 Post By Spieg8
  • 1 Post By TrailTrash
post #1 of 9 Old 05-21-2016, 06:01 PM Thread Starter
TrailTrash
1979 CJ5
Just curious if there is an available 'shorter' pitman arm that I can buy to replace the stock one? Currently, my pitman arm comes into contact with the steering arm under heavy suspension travel.
I wish I could tell you what suspension it's got, but I don't really know. I bought it as it sits, and the guy I bought it from got it on a trade for his travel trailer
Is this a common problem?
This is my first Jeep, I'm a bit of a noob... Wanting to learn
Thanks
TrailTrash is offline
post #2 of 9 Old 05-21-2016, 07:30 PM
y2k-fxst
1964 CJ6
Upload picture to a service like photobucket then paste links to them in a reply. Hard to even attempt to diagnose without at least some visuals.
TrailTrash likes this.
I own a Harley and a JEEP, still some people can't figure out why I'm broke!
y2k-fxst is offline
post #3 of 9 Old 05-22-2016, 06:47 AM
Spieg8
1984 CJ8
I'm, guessing that by "steering arm" you are talking about the tie-rod. If the pitman is hitting the tie-rod under suspension flex, that indicates your front axle has moved forward or the steering gearbox has moved back. Before you go replacing the pitman arm with something shorter (yes there are shorter options), you should try to figure out what is going on (agree that some photos would help).
One increasingly common cause of this is if the front springs have been replaced with YJ springs (YJ spring conversions improve ride comfort but also moves the axle forward about 1/2"). While your taking pictures for us, measure how wide your front leaf springs are (2" = stock CJ width, 2.5" = stock YJ width).
Depending on the cause(s) and severity of the contact, you may be looking at replacing spring bushing, and/or straightening the frame, and/or replacing the pitman arm, and/or installing a steering gearbox mount that positions the gear box forward of the stock location.
When I was younger, I thought I was Don Quixote... turns out I'm just another donkey-hootie.
Spieg8 is offline
post #4 of 9 Old 05-23-2016, 02:46 PM Thread Starter
TrailTrash
1979 CJ5
Thanks for the help. Here is a picture of the front end. Yes, it's hitting the tie rod. You can even see the bend in the picture. Also, it has been converted over to YJ springs apparently, as they are a full 2 1/2" wide.
Mark
post #5 of 9 Old 05-23-2016, 02:55 PM
CrashOdle
1981 CJ7
As mentioned, the YJ springs push the axle forward about an inch. I used a MORE steering bracket that pushed steer box forward 1.25 inches to compensate (and strengthen the frame tie in). While a shorter arm may fix it, you'll lose turning radius.
John Strenk and TrailTrash like this.
81 CJ7 258 Howell TBI/Team Rushed/T19/Scout Dana 300/Dana 44/locked Dana 30/4.10s/rolling 33" KM2's
CrashOdle is offline
post #6 of 9 Old 05-23-2016, 06:02 PM
Spieg8
1984 CJ8
Wow, that tie-rod looks like it was hit pretty hard.
Depending on your tire size and wheel backspace, a shorter pitman may or may not reduce your turning radius from what it is now. My tires for example are large enough that I already had to adjust the steering stops to prevent tire rub on the leaf springs when turning. In my case a shorter pitman arm stopped the contact with the tie-rod but still allowed the front wheels to turn all the way to the steering stops. Much easier/cheaper to replace the pitman than the gearbox mount.
Spieg8 is offline
post #7 of 9 Old 06-25-2017, 07:12 PM
nlcj
1979 CJ7
what kind of pitman arm did you use, Spieg8?? I have this same issue on my 79. Im thinking i have yj leafs put on by the PO as well
nlcj is offline
post #8 of 9 Old 06-26-2017, 09:24 AM Thread Starter
TrailTrash
1979 CJ5
Thanks for your informative answer. I opted for the MORE steering box mount. It not only solved the problem, it's also a much beefier part!
John Strenk likes this.
post #9 of 9 Old 06-26-2017, 10:19 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I had the same problem when I did a Tie Rod flip. The problem was probably there all the time but the stops probably prevented them from hitting. I didn't even have a YJ spring swap.
I went to a Chevy Astro Pitman arm as I need a quick fix. I would of gone with a mount but it would of taken too long.
Here is my post on it. http://www.jeepforum.com/forum/f8/bi...oblem-3835641/
John Strenk is online now
