Piston Rings on straight-six - JeepForum.com
post #1 of 4 Old 01-30-2002, 10:02 PM Thread Starter
nvyblue_cj7
Exclamation Piston Rings on straight-six
The piston rings are supposedly shot on the good old 6 cylinder, the guy told me I could probably get another couple thousand miles out of them before their gone. Should I just replace the old rings, get a rebuild, or just go all out and swap it for an eight cylinder?
1984 CJ7-31" BF Goodrich AT Tires, Auto, 258 ci, Pioneer sound, 2 barrel Weber carb, undergoing some body work and exhaust work sometime soon.
"pop the hood, POP THE HOOD!"
- a phrase commonly heard in my garage
nvyblue_cj7 is offline
post #2 of 4 Old 01-31-2002, 08:02 AM
bodi
Post
I had the same problem with my 83 so i decided to do a complete rebuild. after reading numerous posts about both I6's and V8's i decided to stick with the 258. easy engine and rebuild will be less expensive.
83 CJ7 w/remanufactured jasper 258 I6 w/t-5, Weber carb, new exhaust, PS, PB, 2 1/2" Lift, 31" BFG's, herculined interior and s**t brown paint job (for now) "in to deep..but thats when it starts getting fun"
Brown Jeep Club Member #2
bodi is offline
post #3 of 4 Old 02-03-2002, 07:20 PM
Mugzilla Pavelko
Post
check your compresion before you tear into anything. Sometimes, people screw up and give crappy suggestions. It never hurts to check it out first...
mug
Mugzilla!
RESTARTING a resto that BEGAN in 1985!
1975 CJ-5, 4WD fiberglass tub, 258,... TONS of extra parts!!!
Mugzilla Pavelko is offline
post #4 of 4 Old 02-26-2002, 05:10 PM
Jeep Daddy
Jeep Daddy's Avatar
Post
I second Mugs. Do a compression check. If the compression is better good after a couple of squirts of oil in the cyl., then it's definately bad rings. If the compression doesn't go up when you squirt some oil in there, then you need a valve job. I've heard of people that do valve jobs, and a few miles later they experience blowby because of weak rings. So doing a valve job only is a bit of a risk.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
Small piston groove, can I keep the piston? (picture included) snowrider81 Jeep CJ Forum 14 07-01-2009 05:58 AM
Engine builders...Tell me everything about piston rings twomanyjeeps Jeep CJ Forum 2 10-19-2008 08:30 AM
Bad piston!!! egrasher Jeep CJ Forum 5 02-20-2007 10:01 PM
304 Piston ring gap? swang678 Jeep CJ Forum 13 02-01-2007 04:05 PM
Piston Pic Aphelion79 Jeep CJ Forum 9 08-09-2004 01:54 PM
