Pining on acceleration - JeepForum.com
post #1 of 3 Old 07-26-2013, 09:01 PM Thread Starter
Al_85CJ
I have. 1985 cj with the inline six and and auto trans. Its been sitting awhile after having it smogged. Now when i drive it ping on acceleration. I set timi g to get me the least pinging but it still will not go away. Any suggestions on what to check next?
Al_85CJ is offline
post #2 of 3 Old 07-26-2013, 09:02 PM Thread Starter
Al_85CJ
Um... That should be pinging. Small keyboards and fat fingers do not mix well
Al_85CJ is offline
post #3 of 3 Old 07-26-2013, 10:21 PM
BagusJeep
1981 CJ7
The pinging is detonation and can have several causes, poor fuel and timing are common.
Poor fuel - how old is the fuel? Modern fuel goes stale quite quickly, anything more than 6 months and I would suspect the fuel. A low RON fuel will ping more easily. If it is new and you are using a new source of cheap fuel you may consider changing.
Timing - you have not filled in your Profile so hard to say. IF you have the 258 and the computer still hooked up it may be the computer and its sensors playing up, I understand they are not supposed to ping as the computer will adjust automatically. A Nutter bypass of the sensor wires direct to the ignition ECU rather than through the computer may help.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
