Pilot Bushing Lubricating Wick? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Pilot Bushing Lubricating Wick?
NEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDRear Disc Brake Conversion Kit- TJ,YJ,XJSWAG 50 Cal Ammo Can Mount With M2A1 Can
Unread 07-20-2014, 10:58 AM   #1
Guy Smilie
Guy Smilie's Avatar
1978 CJ5
The FSM mentions it and I've seen it mention here, but I don't have one. Anybody have a picture of one? What kind of material was used, foam? Do I really need it?
Thanks
Guy Smilie is offline   Reply With Quote
Unread 07-20-2014, 11:14 AM   #2
keith460
Jeep. There's Only One
keith460's Avatar
Foam and you need it to lubricate the Oilite bushing.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is offline   Reply With Quote
Unread 07-20-2014, 12:23 PM   #3
Guy Smilie
Guy Smilie's Avatar
1978 CJ5
Keith, would you happen to have a source for this wick?
Unread 07-20-2014, 12:59 PM   #4
1949er
A small chunk of Felt will work soaked in G.O. , I soak the Oilite type bushing in hot gear oil then put a small amount of Grease in there prior to putting in the Trans
1949er is offline   Reply With Quote
Unread 07-20-2014, 01:20 PM   #5
HackFabrication
1976 CJ5
They look like a pool cue tip, but a bit larger in diameter. Get some thick felt and make your own.
"In the end...It's all Hack."
HackFabrication is offline   Reply With Quote
Unread 07-20-2014, 01:20 PM   #6
JeffreyCharles
1976 CJ5
I made mine out of felt and also soaked it in oil, etc. Seems to be working fine.
Jeffrey Charles
http://jeep.smallcraft.net/
JeffreyCharles is offline   Reply With Quote
Unread 07-20-2014, 06:36 PM   #7
keith460
keith460's Avatar
My factory foam piece was just that, small piece of cushion foam soaked in motor oil. Nothing special and you could use a piece of sponge if you wanted.
1984 CJ-7 Renegade
Unread 07-21-2014, 05:00 AM   #8
Guy Smilie
Guy Smilie's Avatar
1978 CJ5
Thanks everyone, I need to look around to see what I have.
Unread 07-21-2014, 10:23 AM   #9
Balvar24
1979 CJ7
I used a sock.
I guess that makes me "that" P.O.
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline   Reply With Quote
Unread 07-21-2014, 03:30 PM   #10
Guy Smilie
Guy Smilie's Avatar
1978 CJ5
Originally Posted by Balvar24 View Post
I used a sock.
cotton or wool?
Unread 07-21-2014, 03:31 PM   #11
Balvar24
1979 CJ7
Polyester I believe, dark blue.
Unread 07-21-2014, 03:40 PM   #12
Guy Smilie
Guy Smilie's Avatar
1978 CJ5
Polyester! That does make you "that PO"
