pilot bushing - JeepForum.com
post #1 of 5 Old 07-02-2009, 12:15 AM Thread Starter
pcairns
pilot bushing
so i have to change my pilot bushing on my 304 to bolt up to my t18
my only prob is getting the old one out any ideas?
pcairns is offline
post #2 of 5 Old 07-02-2009, 06:02 AM
dwloop
1976 CJ5
This is the puller I have, need a slide hammer to use it...
http://www.autozone.com/autozone/cat...uestid=1576064
AutoZone and O'reilly's normally lend them out for a deposit..
HTH
Dave
dwloop is offline
post #3 of 5 Old 07-02-2009, 06:21 AM
rixcj
rixcj's Avatar
1979 CJ5
Try the old grease trick.
Completely fill the void behind the bushing with bearing grease.
Then, find something that will fit inside the bushing pretty snugly ( a piece of roundbar, the large end of a socket extension, etc.).
Place this item into the hole of the bushing, and give it a smack, with a ball peen hammer.
If grease squirts out around your round piece, it's too small (in diameter).
The hydraulic action will usually push the bushing out of the hole. You may have to repeat this a few times.
Is the t-18 a new install for you, or are you re-installing it?
The reason I ask, is because when I swapped a t-18 into my jeep, I had to switch from a tube type pilot bushing, to a disc type pilot bushing.
You may, or may not have to, depending on how long your t-18 input shaft is.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #4 of 5 Old 07-02-2009, 10:13 AM Thread Starter
pcairns
ya i have to it wont fit in
pcairns is offline
post #5 of 5 Old 07-03-2009, 12:42 PM
hunter123
i couldent get the puller in to it either but the puller has like 2 little hooks on the end try to put one side in first then the other side of the puller into it thats how i got mine in
hunter123 is offline
Cj pilot bushing Bahama Blue Jeep CJ Forum 5 01-03-2008 08:05 AM
Pilot Bushing ? coyote7791 Jeep CJ Forum 4 07-29-2007 06:53 PM
t 18 pilot bushing the shootist Jeep CJ Forum 4 09-04-2006 05:40 AM
Pilot Bushing BOSSMAN1967 Jeep CJ Forum 1 08-10-2003 07:26 AM
pilot bushing kdub47 Jeep CJ Forum 0 05-22-2003 12:53 PM
