Pilot Bushing ? - JeepForum.com
post #1 of 5 Old 07-29-2007, 11:02 AM Thread Starter
coyote7791
Pilot Bushing ?
Does anyone know if there should be a lot of play in the pilot bushing? I am swapping a 360 from an auto J10 to a CJ7 with a standard. I took the pilot bushing out of the old 304 that was blown in the CJ and it has some play in it. I have a new one ordered but it doesn't come in until tomorrow. I finally got the old bushing out, but as I said there is play in it. Thanks.
coyote7791 is offline
post #2 of 5 Old 07-29-2007, 11:13 AM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
Where is the play? In the crank, or in the input shaft?
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #3 of 5 Old 07-29-2007, 11:16 AM Thread Starter
coyote7791
input shaft......
it fits tight in the crank (tapped in).....but sloppy in input shaft.
post #4 of 5 Old 07-29-2007, 11:22 AM
Happy Joe
No there should not be "a lot" of play in the pilot bushing. It should be a press fit into the crank and a slip fit onto the nose of the input shaft.
If the transmission changes; i.e. going from a T-18 to a T-176 the bearing should also be changed as there is often a different diameter on the nose of the input shaft.
Sometimes the inside to the bearing is also worn enough to allow slop between the input shaft and the bearing, in this case the bearing should also be changed.
Enjoy!
'06 TJ Rubicon; seemed like a good idea at the time; had many CJs...
Happy Joe is offline
post #5 of 5 Old 07-29-2007, 06:53 PM
dmask0
1977 CJ5
the one i just took out of my cj5 (304 w t150) had almost a 1/4 inch of slop between the bearing and the input shaft. the replacement fit perfectly on the input shaft and had none. i'm not sure if the old bearing was a PO error or was just worn down that much.
dmask0 is offline
Cj pilot bushing Bahama Blue Jeep CJ Forum 5 01-03-2008 08:05 AM
t 18 pilot bushing the shootist Jeep CJ Forum 4 09-04-2006 05:40 AM
Pilot bushing Bulletproofcj7 Jeep CJ Forum 20 09-05-2004 08:36 AM
Pilot Bushing BOSSMAN1967 Jeep CJ Forum 1 08-10-2003 07:26 AM
pilot bushing kdub47 Jeep CJ Forum 0 05-22-2003 12:53 PM
