Picture request: SOA CJ5's! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Picture request: SOA CJ5's!
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 01-20-2011, 11:36 AM   #1
Deadman 94 xj
1977 CJ5
CJ7's welcome too
Please list springs used and tire size.
I'm trying to figure out how low I can make a SOA CJ. The plan so far is to use stock YJ springs.
I'm also toying with the idea of a SOA front and SUA rear
I have searched a ton and if you guys have any good links I might not have seen, please post them up.
Thanks.
77 CJ5. 304, t-150, D20
Deadman 94 xj is offline   Reply With Quote Quick reply to this message
Unread 01-20-2011, 11:44 AM   #2
Deadman 94 xj
1977 CJ5
Axles will be 58" D44's.
Tire size, 35's.
I am aware of the extra work and $$ involved in SOA. I'm just toying with ideas here.
A traction bar will be installed to reduce axle wrap if I SOA the rear.
The hybrid, SOA/SUA setup will have some benefits.
Front SOA:
1). Better wheel travel up front (debatable)
2). Softer ride up front, where all the weight is. (debatable)
3). Better aproach as there won't be any brackets to get hung up on. (debatable)
Rear SUA:
1). Axle wrap will be minimized.
2). Added stability in the rear, forcing the front to do more "work".
3). Driveline angle advantages since the CJ5 is so short.
You're probably asking, then why go SOA to begin with? So am I!
Thoughts?
Unread 01-20-2011, 11:56 AM   #3
CSP
There's a thread on CJ's on 35s or larger tires. Many in that thread are spring over.
One way to lower the COG while spring over is to french the spring and shackle hangers into the frame rails rather than mounting them on the bottom of the rails.
CSP is online now   Reply With Quote Quick reply to this message
Unread 01-20-2011, 12:06 PM   #4
Deadman 94 xj
1977 CJ5
Ok, I'll check that out. Thanks.
Unread 01-20-2011, 12:49 PM   #5
GraKee99
Rapist Wit
GraKee99's Avatar
Here is mine. YJ stock springs with widetrack axles and 33s. I am redoing everything but this was before disassembly.
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote Quick reply to this message
Unread 01-20-2011, 01:16 PM   #6
Deadman 94 xj
1977 CJ5
Thanks GraKee99, that doesn't look too high. I'd say it's right on the line of where I want to be, no higher.
Were you happy with the way the suspension performed? Basically any feedback, good or bad, would be great. Street and trail.
Unread 01-20-2011, 01:28 PM   #7
82JeepCJ7
1982 CJ7
Front
Rear
Spring over and 33s
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline   Reply With Quote Quick reply to this message
Unread 01-20-2011, 01:33 PM   #8
Deadman 94 xj
1977 CJ5
Here's one I found that I like, for obvious reasons. This was taken out of a 4WD online article.
I like how he frenched in the rear. I'm not sure what he did on the shackle side though, if anything.
I don't know what he did up front. It looks like a fabbed rear hanger but I'm not sure if the center bolt sits closer to the frame or not. I'd need to look at mine again. For the front shackle, again, I'm not sure what he did but they look as if they might be frenched in as well.
No idea what springs he used, custom, ect. It almost looks like stock "narrow" CJ springs up front.
I think I'd be scared to cut into my frame like that. I guess a little plating on the outside would ease any worries.
Unread 01-20-2011, 01:34 PM   #9
Deadman 94 xj
1977 CJ5
82JeepCJ7, nice jeep!
Stock shackles, YJ stock springs? That looks great!
Unread 01-20-2011, 02:01 PM   #10
CSP
The thing to do is build a "box" inside the frame rails that contain the ends of the springs. Plating won't do much when you take away that much on the bottom side of the rail.
Unread 01-20-2011, 02:16 PM   #11
Deadman 94 xj
1977 CJ5
Ok, I see what you're saying. I'm sure I can search around and find some details if I were to go that route.
Welding in there would prove quite challenging I'd imagine. Or do you think it's just a matter of proper execution? Build it first and stuff it in there type thing?
Unread 01-20-2011, 02:57 PM   #12
CSP
Yep, build it first and then incorporate that into the rail.
Unread 01-20-2011, 03:36 PM   #13
82JeepCJ7
1982 CJ7
Those are the stock springs and shackles. I used the original sway bar links to build my own disconnects. Basically cut the ends off and welded on some DOM tube and solid bar, then drilled a cross hole where the hitch pin goes in. The links are shorter than stock due to using the original front spring plates. The plates have to be switched side to side in order to use the sway bar stud. But in doing so, you have to either slot, or fill and redrill the holes for the U-bolts because the one U-bolt is bigger on the passenger side that goes around the pumpkin. I used a 4" drop pittman arm and my drag link came out flat. I get no bump steer at all. It rides great. Handles great. And the flex is awesome.
A friend of mine was running a 4" spring lift on his CJ. After wheeling with me one day and seeing how well mine flexed compared to his, we did a SOA on his about 2 weeks later using Wrangler springs. He ended up trading his lift springs strait across for the stock springs.
Unread 01-20-2011, 03:46 PM   #14
82JeepCJ7
1982 CJ7
Here is a couple old pics.
Unread 01-20-2011, 03:51 PM   #15
Deadman 94 xj
1977 CJ5
That's awesome. Thanks for the help and the feedback, here and in the other thread. I definitely plan to run the sway bar on the street and that helps. That jeep sits perfect.
