picture of fuse block 86 cj7 - JeepForum.com
post #1 of 19 Old 12-09-2011, 10:24 AM Thread Starter
timh1254
Writing is worn of my 1986 cj7 fuse block.Anybody have a picture or diagram of the original?
timh1254 is offline
post #2 of 19 Old 12-09-2011, 10:39 AM
FLynes
De Oppresso Liber
FLynes's Avatar
1976 CJ5
Here you go. It's the best I have.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #3 of 19 Old 12-09-2011, 10:39 AM
Outnumbered
1985 CJ7 California model with AC, Clock, and Auto Trans. I think the orange plug is the clock (there are two clock plugs). AC is not plugged in. I just realized PO has a 20amp fuse in a 10amp slot
1985 CJ7, 258, TF999, D300, D30, AMC20, 4.5" lift, 33" BFG's
Outnumbered is offline
post #4 of 19 Old 12-09-2011, 10:43 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Just ignore the extra turn signal flasher.
John Strenk is offline
post #5 of 19 Old 12-09-2011, 10:48 AM
Outnumbered
So mine is correct with only one flasher? My signals work but I have not checked hazards. I noticed a flasher in the wire harness near the fuse block. Have not got to the electrical on my jeep yet. Working on mechanical stuff now and battery is disconnected.
post #6 of 19 Old 12-09-2011, 10:50 AM
Outnumbered
What does the big metal GTE (breaker?) do?
post #7 of 19 Old 12-09-2011, 10:55 AM
John Strenk
1976 CJ5
Yes that's right, only one flasher in the fuse box for hazard. Turn signal flasher behind parking brake. Might be what you saw up there.
Look for red and yellow wires.
That is a circuit breaker for the wipers. Any thing you might want to keep working after a momentary short should use a self resetting Circuit breaker. Like headlights and wipers.
post #8 of 19 Old 12-09-2011, 10:56 AM Thread Starter
timh1254
Wow.... Thanks to all! Outstanding!
timh1254 is offline
post #9 of 19 Old 12-09-2011, 10:59 AM
Outnumbered
Thanks! Now I have more q's
What are the T/G's and LPS ???
Where is the headlight breaker?
Should my turn signal flasher relay be mounted or loose in the harness?
post #10 of 19 Old 12-09-2011, 11:00 AM
Outnumbered
Ahhh...thanks for the pix. They were not showing when I asked my q's
post #11 of 19 Old 12-09-2011, 11:06 AM
John Strenk
1976 CJ5
T/G is Tail Gate Power (window, Release? ). very popular option on the CJ
Head light Circuit breaker is inside the headlight switch.
T/S flasher is just loose in the harness. At least it always has been in the ones I've looked at.
LPS? Low Power Stuff? I don't know but usually for stuff like Panel lights and powering Speedo electrical stuff
post #12 of 19 Old 12-09-2011, 11:16 AM
Outnumbered
Thanks!
post #13 of 19 Old 08-10-2012, 04:31 PM
DENVAR03
hi
i have no power anywhere,you can see my post,on DENVAR03.some one said i should find the fuseable link in my fuse box,but i can't locate any.
dennis
DENVAR03 is offline
post #14 of 19 Old 08-10-2012, 04:35 PM
Outnumbered
Originally Posted by DENVAR03 View Post
hi
dennis
Fusible link is not in the fuse "box" its in the harness near the alternator. Search and you should be able to find some pics.
post #15 of 19 Old 08-14-2012, 07:32 PM
DENVAR03
JOHN
sorry to cut in,but i know you help so many of us,i have a Q.i have power at fuse box,for directionals,as well as at red/wht./yellow wire going to flasher.i have no signals,either left or right,and no hazard either.can you tell me where to check!!!.
thanks dennis
DENVAR03 is offline
Fuse Block NC78CJ7 Jeep CJ Forum 3 07-20-2011 09:59 PM
79 CJ 5 Fuse block kluman Jeep CJ Forum 4 04-28-2010 11:09 AM
Picture request of the fuse block back in the engine compartment gmakra Jeep CJ Forum 7 06-21-2009 07:14 PM
Fuse Block Picture CJman77 Jeep CJ Forum 3 01-30-2004 11:22 PM
fuse block? onesojourner Jeep CJ Forum 4 01-24-2003 11:24 PM
