pics of your cj's with tube fenders - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > pics of your cj's with tube fenders
Unread 05-23-2014, 03:31 PM   #1
agear
Im putting on a new tub and getting a paint job and im thinking about getting tube fenders. Will you post pictures of your cj with tube fenders and say what lift and tire size you have
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline   Reply With Quote Quick reply to this message
Unread 05-23-2014, 04:48 PM   #2
mwroseberry
79 CJ7 no lift with 33s
CCFabs hoodline 3" tube fenders in front
Poison Spyder Crusher armor in rear
Fenders as I was installing them:
SGT USMC ret. - Fallujah 06..........Never forgotten
'79 CJ7 with 4.2L w HEI /Dana 300 - twin sticked /Dana 30/AMC 20/ 33"BFGs-CCFabs tube fenders - Spyder Trail Stinger
http://www.jeepforum.com/forum/f22/project-franken-jeep-cj7-1981474/
mwroseberry is offline   Reply With Quote Quick reply to this message
Unread 05-23-2014, 05:19 PM   #3
76cjnoob
1976 CJ7
2.5 inch lift with 33x10.50 bfg at's. Homemade tube fenders and tj flares in the back
76cjnoob is offline   Reply With Quote Quick reply to this message
Unread 05-23-2014, 09:12 PM   #4
agear
Are your rear tj flares modified(cut narrower) or stock
Unread 05-24-2014, 03:07 AM   #5
vinnyabs
1983 CJ7
Do metal cloak count?
Earning an engineering degree one CJ7 hiccup at a time
vinnyabs is offline   Reply With Quote Quick reply to this message
Unread 05-24-2014, 04:14 AM   #6
76cjnoob
1976 CJ7
I trimmed about an inch off the bottom on both ends. Other than that they are stock
Unread 05-24-2014, 06:32 AM   #7
04Xmatt
Originally Posted by vinnyabs View Post
Attachment 1362409
Where did you get those tail lights???
1985 CJ7. Cummins 4BT, SM465, Dana 300. 4inch lift. Fiberglass tub.
04Xmatt is offline   Reply With Quote Quick reply to this message
Unread 05-25-2014, 04:01 PM   #8
vinnyabs
1983 CJ7
They are off a M998 hmmwv. Thanks. Always nice when someone appreciates your hard wirk
Unread 05-26-2014, 01:40 PM   #9
4S50
35" Goodyear MTRs, 3" Black Diamond in the front, 3.5" YJ Black Diamond in the rear, 1" body lift with Genright 4" fenders.
4S50 is offline   Reply With Quote Quick reply to this message
Unread 05-26-2014, 02:13 PM   #10
holliewood61
1981 CJ7
4" springs, 35x14.50's on 15x12's, diy tube fender kit.
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is offline   Reply With Quote Quick reply to this message
Unread 05-27-2014, 03:53 PM   #11
agear
Holliwood61,got any straight on front shots ?
Unread 05-27-2014, 04:57 PM   #12
holliewood61
1981 CJ7
This is before the 8274 went on
08 WK bone stock
00 WJ daily driver
60 CJ5 tore down
Unread 05-27-2014, 05:58 PM   #13
agear
Cool thanks
Unread 05-28-2014, 09:22 AM   #14
holliewood61
1981 CJ7
With the winch if that's helps more
08 WK bone stock
00 WJ daily driver
60 CJ5 tore down
Unread 05-28-2014, 03:18 PM   #15
agear
Yes thanks that doesn't look bad
