Quantcast Pics of the Jeep Tub Swap Project - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Pics of the Jeep Tub Swap Project
Old 12-25-2007, 01:08 AM   #1
medunwoody
So since Christmas vacation finally came around I've got a month off from college to work on my jeep. The plan that I have is to replace the tub that is currently on my '85 cj7 with a '91 yj tub. The jeep is mechanically sound and the frame has almost no rust. The body however has a lot of rust that just has to go. I plan on swapping the body out and painting both the body and the frame and herculining or something the interior. Hopefullly, I'll be able to replace a few parts and upgrading along the way. I am going to use the original fenders that were on the jeep and found a newer hood with no dents. I got the yj tub fairly cheap because it was in a fire. The only damage aside from surface rust is a little warparge around the vent on the cowl. Anyways I'm sure I'll have plenty of questions along the way. So far I've removed the old tub and have the *new* one dropped in. I'm working on fixing the vents, tailgate, and other fitment issues that are involved with the different tubs before I pull it off to be painted.
1985 CJ-7 with 4bt Cummins Turbo Diesel, nv4500, dana 300, 4.56 gears in stock axle housings just waiting to blow up with the extra power!
Medunwoody@aol.com
Columbia, MO
medunwoody is offline   Reply With Quote
Old 12-25-2007, 01:17 AM   #2
jeepskate
Good luck...you've got a good support group here to work with and your goals are certainly attainable if you stay on track.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
http://www.jeepskate.net
jeepskate is offline   Reply With Quote
Old 12-29-2007, 11:37 AM   #3
medunwoody
Does anyone know where I could get a hydraulic clutch conversion? I was kinda wanting something that works a little better than the stock mechanical one? I have the 258 with the T-5 if that helps at all.
Medunwoody@aol.com
Columbia, MO
Old 12-29-2007, 12:31 PM   #4
molsenice
1964 CJ5
click free
molsenice is offline   Reply With Quote
Glock Forum
