picked up a cj5 and have axle questions - JeepForum.com
post #1 of 17 Old 05-02-2012, 07:18 PM Thread Starter
theredmonster
ok im new to the cjs. ive built 3 yjs, 2 tjs and have a stock jk as my daily driver. the cj5 seems really narrow and i would like to widen it a little to make it a little more stable. is the axles out of a yj to wide or did another cj have wide axles? would also like to put disc brakes on the front too
Edit: jeep is 100% stock and original 74 model
12 half door wallet killer in the making
theredmonster is offline
post #2 of 17 Old 05-02-2012, 07:27 PM
John N
1981 CJ8
YJ axles have the front diff on the wrong side and usually a weak Dana 35 rear. '82 to '86 CJs have wider axles and front disk brakes, but usually worse gear ratios than what you probably have. You should currently have 4 wheel drum brakes with a Dana 30 front and a 44 rear. Yes, they're narrow track, but give them a chance before you ditch them. Think of where you can fit with it that narrow.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #3 of 17 Old 05-02-2012, 07:40 PM Thread Starter
theredmonster
that is true. im worried about rolling it mostly. but the brake upgrade is a must. will the brakes be an easy swap? techincly i should be able to get just the knuckels off a 76 and newer cj right?
post #4 of 17 Old 05-02-2012, 08:10 PM
BrandonJames
1974 CJ5
I have a dana 30 that has disk brakes, pulled it from my 74 cj5. let me know if your interested in the knuckles, its just sitting outside rusting, and im not using it for my jeep so just pm me.
BrandonJames is offline
post #5 of 17 Old 05-02-2012, 08:13 PM
BagusJeep
1981 CJ7
One alternative is wheel spacers, whcih can get you another few inches on the track. Just make sure you buy some quality ones and not the eBay ones which are generally lower strength.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #6 of 17 Old 05-03-2012, 12:40 PM Thread Starter
theredmonster
i was thinking about useing wheel spacers. one reason i was thinking of changing axles is that ive always heard that the cjs were bad about breaking the axels. is this true?
post #7 of 17 Old 05-03-2012, 01:53 PM
rignrider
1960 CJ5
I am running a little older CJ but I put Scout axles under it. They are disc up front and both front and rear are dana 44's. The only downfall they are a bit higher gear ratio, but they will work out fine.
rignrider is offline
post #8 of 17 Old 05-03-2012, 02:12 PM Thread Starter
theredmonster
intersting, never thought about scout axles. a 44 in the front would be nice to. how much wider are the scout axles?
post #9 of 17 Old 05-03-2012, 02:42 PM
colojeepguy
1970 CJ5
If stock, you should have a Dana 44 30 spline rear. This is plenty strong for a CJ unless you're getting crazy with giant tires or lots of HP.
colojeepguy is offline
post #10 of 17 Old 05-03-2012, 04:44 PM
rignrider
1960 CJ5
Ya know if I remember right they are 50 ish inches wide
post #11 of 17 Old 05-03-2012, 05:31 PM
BlueRubiconrich
A Scout 2 Dana 44 front end is aabout 2 5/8 wider
1 some people outboard them
2 I had mine cut and the knuckles rewelded back on at 10 degrees for camber.
then I got a chromolly shaft had it cut and resplined to fit.
Scout 2 axles don't have enough camber so you have to rotate the knuckles.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #12 of 17 Old 05-03-2012, 05:34 PM
BlueRubiconrich
and don't rule out Waggy axlers
post #13 of 17 Old 05-03-2012, 07:24 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I think the main question for axle choice is your planned use for the vehicle? A 99% DD doesn't need much for upgraded axles.
I've had the stock narrow axles under mine (78 CJ5) since I bought it, and DD it 90% of the time. I have driven it thru winters with Ice, snow, rain, sun. Drove it the ten hours to Chat, TN and then back, and never once feared it tipping or rolling. Under normal use, I don't think that would be an issue. Just remember off-camber angles are not good and avoid them!
Rick
Cutlass327 is offline
post #14 of 17 Old 05-03-2012, 08:30 PM Thread Starter
theredmonster
it will be my dd in the summer most likely and do some trail riding in gilmer,tx. i dont plan on making any long trips in the cj5 thats what the jk is for. i just want to be able to go have fun and not worry about the dana 30 breaking.
post #15 of 17 Old 05-04-2012, 12:03 AM
BagusJeep
1981 CJ7
I have drum brakes on Puthijeep and they take a little getting used to but are fine for DD and wheeling. Unless I was going to us eit for long highway high speed trips I would not go to the bother of changing them.
Axle questions E_Rector Jeep CJ Forum 3 11-14-2011 04:35 PM
Axle Questions MightyLampshade Jeep CJ Forum 18 05-10-2010 12:57 PM
Just picked up my first CJ...couple questions scanos Jeep CJ Forum 0 02-25-2009 12:45 PM
Axle questions? 918wheeler Jeep CJ Forum 3 01-23-2009 05:49 AM
amc 20 1 pc axle questions deerslayer Jeep CJ Forum 1 12-27-2005 05:18 AM
