penetrating oil - JeepForum.com
post #1 of 11 Old 06-06-2002, 01:15 PM Thread Starter
KG4PAM
Post penetrating oil
any suggestions or hints on removing frozen(rust) bolts? i am changing the check valve on my junkyard A.I.R. manifold and it is frozen up. i have hit it a few times with WD-40, but it is still tight. ideas? thanks! jairus
'81 CJ-7 Got it when I was 16!
'06 Hummer H3, boulder gray, Adventure Package(electric rear locker and 70:1 crawl ratio BONE STOCK)
'71 Kaiser-Jeep M35A2 Deuce and a Half cargo truck, with winch. <for sale>
KG4PAM is offline
post #2 of 11 Old 06-06-2002, 09:07 PM
Dustin Maschino
Post
i dont know if they have it where you live, but we use this stuff called "PB Blaster" and its 2-3 times better than WD-40...
Dustin Maschino is offline
post #3 of 11 Old 06-07-2002, 08:27 AM
4wheeler4CJ
4wheeler4CJ's Avatar
Arrow
Liquid Wrench usually works better than WD-40, but also try putting heat to it, almost always works great, never had it fail for me. <img border="0" title="" alt="[Wink]" src="wink.gif" />
4wheeler4CJ is offline
post #4 of 11 Old 06-07-2002, 02:25 PM Thread Starter
KG4PAM
Post
thanks, i will try to find those! i thought about heat, will try that too. is a hair dryer hot enoough, or should i use a quick swipe of the oxy-acytelene thanks again!
KG4PAM is offline
post #5 of 11 Old 06-07-2002, 04:47 PM
West
Post
what I've found works ok is a Mapp torch it's small but pretty effective and it can be found at a hardware store for under 30 bucks.
West is offline
post #6 of 11 Old 06-07-2002, 07:02 PM
Boggy Bottom
Post
Here is where I spew a ton of crap about penetrating oils! &lt;grin&gt;
WD-40 and the like will penetrate, but Liquid Wrench, Cyclo Breakaway, PB Blaster, and the like are all catalytic types which will actually creep into solid rust a lot better. My fave right now is the PB, not because I think it works better, but I like the smell better than the Breakaway!
I use Kroil whenever I can get it, and just apply it with a cheap brush out of a soup can. Kroil is pretty good, but IMO it's really nothing more than Lestoil and tranny fluid. I mixed up some of this once and it works actually quite well. I have used Lestoil for years to free frozen motors and so on. Weird stuff, but it works. I usually go in equal parts Lestoil, transmission fluid, and kerosene. This mixture will really do a great job of cleaning out your motor if you need to flush out the sludge.
You could add some WD40 to the mix if you like but kerosene is not far from the viscosity and lubricating qualities of WD40 anyway.
I'm surprised that Marvel Mystery Oil hasnt been mentioned yet. In my opinion this is merely good-smelling, and dyed red, kerosene. Oh while I am on a kerosene kick here, Diesel fuel will work just as well too.
Look on a can of Marvel. It reads there are many different ways to use it. Know what? You can use kerosene with all the same effects. Why I have seen my father hold the throttle open on an engine and slowly pour a pint of kero in the carb. It smokes like hell, but cleans and removes varnish deposits, and unsticks floats, etc, just like Marvel. In the end, the can of whatever you buy will be spent, and you'll have to get another. Just get whatever is cheapest, and above all, patience is key.
Goosing a rusted part up real nice with penetrant and then letting it sit awhile will make it easier to get it off. The stuff really dont work awefully fast.
Well thanks for reading all my rambling crap. As a professional mech, one tends to see almost everythign over the years. Hope some of this will help you.
Peace
Ol' Boggy Bottom
'83 & '84CJs, '51, '53, and '57 Willys Pickups
Boggy Bottom is offline
post #7 of 11 Old 06-07-2002, 09:59 PM
Bulletproofcj7
Post
Get the torch out! get it nice and hot(red hot) then douse it with lots of water. the metal around the bolt will expand and contract at a different rate than the bolt itself,thus breaking the rust between!
be careful though! comon sense comes into play.
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
post #8 of 11 Old 06-08-2002, 11:56 PM
RustyCJ8
Talking
Pb blaster and breakaway are awesome products.The breakaway has an evil odor though.. <img border="0" title="" alt="[Eek!]" src="eek.gif" />
Keep it on all fours.Most of the time anyway..;-)
RustyCJ8 is offline
post #9 of 11 Old 06-09-2002, 07:35 PM Thread Starter
KG4PAM
Post
thanks for the replys, ill see what i can do. btw, boggy bottom, you are a "slick" writer... har har har
KG4PAM is offline
post #10 of 11 Old 06-10-2002, 06:31 PM
Boggy Bottom
Post
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by KG4PAM:
<strong>thanks for the replys, ill see what i can do. btw, boggy bottom, you are a "slick" writer... har har har</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">Just glad I can "lubricate" a solution to your rusted bolt problem. =)
Ol' Boggy Bottom
post #11 of 11 Old 06-12-2002, 05:36 AM Thread Starter
KG4PAM
Post
sure enough, pb blaster worked!
KG4PAM is offline
Penetrating Oils Compared wellmax Jeep CJ Forum 28 06-11-2009 01:23 PM
