12-30-2009, 11:24 AM
#1
PCV valve vacuum...how much is too much
I'm running a Howell TBI unit and it says to hook the PCV up to manifold vacuum.
At idle I'm getting a ton of suction.
I didn't think you should get suction at idle???
I also have a problem with not being able to get my idle down to 750 rpm.
No matter what I do it goes up to around 1,000 rpm as soon as it goes to closed loop.
I did check the programming and it's set for 700 rpm.
If I take the PCV out and plug it, the idle goes down.
So...it's acting like a vacuum leak.
Should I need to restrict my vacuum line down???
Jim
85 CJ-7, 258 I6, 35's, 4" BDS suspension lift, 1" body lift to clear tires, swaybar disconnects, Currie tie rod and steering rod, Rusty's BEEFY steering gear mount, Steering brace, Superior one piece axles, Detroit locker rear and Detroit TT up front, T5 Tranny, Dana 30, AMC 20, Dana 300 TC,TR upgrade, and Howell TBI.
12-30-2009, 11:33 AM
#2
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Sounds like a bad PCV valve. They have a ball bearing in them so they shut off at high vacuum like when at idle. The Jeep one is also supposed to have the canister's (gas tank vent) flow into it when at speed to suck right.
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
12-30-2009, 12:08 PM
#3
Thanks Mike!!!
Unfortunately I think my charcoal canister in bad.
Since the PCV valve is new, I started checking the other end...when I pinch the purge line that the PCV is plugged into, the idle drops
Guess I need to start looking for a new one.
12-30-2009, 12:17 PM
#4
Originally Posted by CJ7_Jim
Thanks Mike!!!
Unless the plumbing is wrong so it is turned on at idle? It is supposed to get a ported signal via the CTO valve so it only turns on at speed when warmed up. I would pinch the small signal line closed to see if it shuts off first. If it still purges at idle, then check this link for part numbers. http://www.jeepforum.com/forum/f8/cj...ml#post5732729
Mike
12-30-2009, 01:16 PM
#5
It must be getting the signal from the CTO.
Everything is fine until it warms up.
Once it heats up the idle goes up.
I checked the signal hose and nothing happens when I pinch it.
It does drop rpm's when I pinch the purge hose though.
Does this sound like a bad canister
12-30-2009, 01:21 PM
#6
Unfortunately yes. One last test would be to unplug the little signal line so then you are real sure it isn't turned on by mistake.
Mike
12-30-2009, 03:49 PM
#7
The PCV is supposed to get full manifold vacuum. The check ball is designed to close when an intake backfire occurs to prevent flames from igniting any fumes in the crankcase.
curly
I start what I finish!
12-31-2009, 06:30 AM
#8
curly
PCV valve - Wikipedia, the free encyclopedia
It also cuts the flow almost off at high vacuum so that line he was seeing collapse sounded like a weak line on a properly working canister at first. Now I am not sure. If the canister is venting at idle, then the air filter on it must be plugged and it must have a bad shut off valve to cause that collapse.
Mike
12-31-2009, 07:26 AM
#9
The PCV valve should be closed at high vacuum like at idle. However is you have a vacuum leak, then your vacuum level will drop opening the PCV valve creating a bigger leak. It is also closed at low or now vacuum also.
12-31-2009, 10:35 AM
#10
With the Howell unit, you end up with very limited vacuum hoses.
I replaced all of them when I installed the tbi a few months back.
I don't think I have any other vacuum leaks anywhere.
I've checked countless times with carb cleaner, spraying it everywhere.
The canister must be bad....and I did change the filter just in case.
When the engine heats up the idle goes up.
If I pinch the purge ling at the canister the idle drops.
I'm thinking the diaphram in the canister may be cracked.
12-31-2009, 10:39 AM
#11
That is the test for a torn diaphragm. The only other test I can think of is to unplug the line from the CTO to the canister so it for sure can't be turned on. If it still acts the same, then you have it for sure.
Mike
