PCV valve question....Oil coming out of dipstick. - JeepForum.com
post #1 of 7 Old 09-15-2011, 05:39 PM Thread Starter
StormRider01
1977 CJ7
I have a 77 Cj7 with a 304. Just rebuilt the motor on it. When it runs, oil is coming out of the dipstick. I did put a pcv valve that I got from Autozone on but it seems like it's just a big black plastic tube that's hollow in the middle. Also, is it suppose to connect to the port at the bottom of the carb in the back? I unhooked the pcv and didn't feel too much vacuum pulling from the intake and the motor runs fine. Actually oil doesn't come out of the dipstick when I don't hook up the pcv. Is that normal for these motors? Also, the oil filler cap has a port with a hose on it. Is that suppose to hook up to the bottom of the air cleaner. I have an aftermarket Holley round air filter and I believe there's a port for a hose underneath. The previous didn't have any of these hoses hooked up so I am trying to figure them out.
Thanks,
Storm.
Life is Too Short.......Work Hard.....but PLAY HARDER!!!!
StormRider01 is offline
post #2 of 7 Old 09-15-2011, 06:10 PM
lucdog
lucdog's Avatar
1980 CJ5
You probaley know this, but I don't know if you know. The location of the PCV on the 304? And it does go to one of the larger ports on the carb. There should be enough vaccume, that when unplugged, the engine wants to stop running. You are correct about the oil fill cap vent, this were the fresh air is drawn into the engine.
The only reason for oil to come out the tube, is internal pressure in the crankcase,
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3 of 7 Old 09-15-2011, 07:16 PM Thread Starter
StormRider01
1977 CJ7
Yes I know the pcv has a grommet and it goes in the middle back of the intake on a 304. The one I got from Autozone is not like a regular one. It's just a hollow tube seems like and it is big also 3/4 inch. Does anyone have a part number of the one for a 304? Thanks.
post #4 of 7 Old 09-15-2011, 07:26 PM
FLynes
1976 CJ5
PCV127.
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #5 of 7 Old 09-15-2011, 07:38 PM
lucdog
lucdog's Avatar
1980 CJ5
The hose you need is only 5/16" or 3/8" ID. I'm courious, can you suck air from either end of the hose you have?
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #6 of 7 Old 09-15-2011, 07:45 PM Thread Starter
StormRider01
1977 CJ7
Yes because the hose is new and the pcv that autozone sold me seems hollow in the middle.He had the other end of it in the oil filler cap that's why there wasn't any vacuum to vent the pressure in the engine.
post #7 of 7 Old 09-15-2011, 08:29 PM
lucdog
lucdog's Avatar
1980 CJ5
So does this mean your good to go? Sounds like it.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
blow by , oil , pcv
258 blows oil out of valve cover and dipstick bubbab Jeep CJ Forum 2 01-07-2011 06:07 PM
my 258 blows oil from the dipstick, valve cover... Blow by? godrocksus1 Jeep CJ Forum 14 04-01-2009 03:51 PM
Oil coming out the dipstick medunwoody Jeep CJ Forum 2 10-14-2006 05:46 PM
oil coming out dipstick area! adamblitzer Jeep CJ Forum 9 10-18-2005 10:41 AM
Tranny Fluid coming out of Dipstick pipthenapster Jeep CJ Forum 2 07-18-2005 09:19 AM
