PCV Valve location on 258 - JeepForum.com
post #1 of 5 Old 07-21-2007, 04:46 PM Thread Starter
AMC Power
Does it matter which hole you put the PCV valve into on the valve cover? I know that the other hole is supposed to be connected to the air cleaner.
AMC Power is offline
post #2 of 5 Old 07-21-2007, 05:13 PM
shaker man
No,as long as they are both connected. if you have the oem air cleaner the pcv is in the front. if you do not, be sure to have some kind of filter on the inlet side of the valve cover.
shaker man is offline
post #3 of 5 Old 07-21-2007, 05:50 PM Thread Starter
AMC Power
I am hooking up a holley 390 and the air cleaner that I got to go with it has a small tube sticking out of it for the valve cover vent. So if I just go with the same setup as oem, then I will be fine?
post #4 of 5 Old 07-21-2007, 08:22 PM
shaker man
your gonna put that carb on a six? your stock air cleaner will not work. look for an aftermarket cleaner with the intake tube for the valve cover vent on the inside of the air filter.
post #5 of 5 Old 07-22-2007, 06:40 AM Thread Starter
AMC Power
I already got a K&N air cleaner setup for the carb that has the vent tube on the bottom.
PCV Valve location/Valve cover replacement jobst Jeep CJ Forum 2 03-28-2010 01:53 PM
Brake Prop Valve location ctm Jeep CJ Forum 1 11-13-2009 06:47 AM
Liquid check valve location on fiberglass tub... hex Jeep CJ Forum 7 01-09-2009 01:24 PM
pressure relief valve location Etchandy Jeep CJ Forum 0 02-28-2008 09:27 PM
4-151 EGR-CTO Valve Location? Mark Wasakoski Jeep CJ Forum 6 03-20-2006 05:54 PM
