PCV valve on a 4.0 headswap? - JeepForum.com
post #1 of 4 Old 10-05-2010, 05:06 PM Thread Starter
scramblerdude81
1981 CJ8
how should my pcv valve be hooked up should i run the one for the 258?
scramblerdude81 is offline
post #2 of 4 Old 10-05-2010, 06:38 PM
gojeepin
1983 CJ7
Are you using the 258 manifold and carb?
If so, I found a grommet at Autozone that fit the valve cover and the 258 PCV valve.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #3 of 4 Old 10-05-2010, 06:49 PM Thread Starter
scramblerdude81
1981 CJ8
yes, carb and intake
post #4 of 4 Old 10-05-2010, 07:13 PM
gojeepin
1983 CJ7
I took measurements and kept looking until I found grommets for the PCV valve and the filter tube. It took a while but I found them from the assortment of PCV grommets they had on the wall at Autozone or Advance Auto.
gojeepin is offline
258 , 4.0 , pcv , swap
Replacements for Liquid Check Valve/Roll Over valve jpd1899 Jeep CJ Forum 143 08-25-2015 09:07 PM
Changing valve cover gaskets/valve covers gtrpup2 Jeep CJ Forum 20 03-28-2013 07:35 PM
Brake Combination Valve/Proportioning Valve Question Wrangler1642 Jeep CJ Forum 1 01-17-2011 04:43 PM
Deceleration Valve/Anti-Backfire Valve David Augusto Jeep CJ Forum 2 01-30-2009 07:09 PM
Gas check valve and anti roll over valve ? NCHornet Jeep CJ Forum 1 10-10-2006 06:18 PM
