PCV Issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > PCV Issue
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! The Ruffstuff 9" Disc Brake brackets!Even Better Heim Pricing! From Ruffstuff
Unread 07-31-2015, 09:36 AM   #1
84CJrox
PCV Issue
I have a 1984 CJ7, 258, with a carter BBD. My engine has two PCVs, one front and one rear. My rear PCV is connected to a hose that is connected to nothing. There is no way that this is correct. My carb has an aftermarket air cleaner, so no hookups there. If anyone can help me out, I would greatly appreciate it.
84CJrox is online now   Reply With Quote Quick reply to this message
Unread 07-31-2015, 10:04 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
The rear is an open elbow intake that should have an air filter on it. They sell ones you can just plug into the hole.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 07-31-2015, 10:05 AM   #3
LumpyGrits
Cj
That's wrong-
That rear one should be a hose go'n to the A/F housing.
Here's how it should look, if you have all the SMOG stuff still.
http://home.sprynet.com/~dale02/vacuhose.htm
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline   Reply With Quote Quick reply to this message
Unread 07-31-2015, 10:09 AM   #4
84CJrox
Originally Posted by LumpyGrits View Post
That's wrong-
LG
Thanks for the link. The only problem is that I don't have the stock air filter housing, although there are times that I wish I did.
Unread 08-01-2015, 05:40 AM   #5
Mike Romain
http://www.ebay.com/bhp/crankcase-breather
Mike
Unread 08-01-2015, 08:21 AM   #6
Ken4444
Corripe Cervisiam
Ken4444's Avatar
The PCV valve should have hose running to the carburetor's manifold vacuum connection. This draws vapor out of the crankcase. The other hole in the valve cover should connect to a filter of some type, either on the factory air filter housing or just a breather that you stick into the valve cover, as mentioned above. This allows filtered outside air into the crankcase.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline   Reply With Quote Quick reply to this message
Unread 08-01-2015, 08:57 PM   #7
84CJrox
I'll take a picture of what I'm working with once the weather clears up.
