PCV Help please - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > PCV Help please
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 04-04-2014, 12:54 PM   #1
rjf1978
PCV Help please
The front hole in the valve cover (like the rear one where the PVC valve is) had a filter installed buy the PO. Well that filter gets saturated with oil vapor and drips oil onto the valve cover. My question is...can I just get another piece of tube and install a "Y" connection to tie it in to the PVC tube? Or as a general question...what am I supposed to do with this hole?
rjf1978 is offline   Reply With Quote
Unread 04-04-2014, 01:29 PM   #2
crouse11c
First throw the breather in the back and the PVC valve in the front. Also make sure the PVC valve is working by shaking it and listening for a rattle. If it rattles good to go if not inspect and or replace.
crouse11c is offline   Reply With Quote
Unread 04-04-2014, 01:43 PM   #3
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Crankcase vapor, gas, fumes should be drawn through the PCV valve. Outside air should be drawn in through the other hole, ideally through some kind of filter. As the previous reply suggested, make sure the PCV valve rattles. Also make sure the PCV valve is correctly connected to a vacuum source so that it does draw vapor out of the crank case.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline   Reply With Quote
Unread 04-04-2014, 01:43 PM   #4
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
The engine has an in and an out. The filter should be on the rear as mentioned. Most covers have a baffle under the hole so not too much blow by gets out.
Excessive blow by can mean the engine is getting tired or the charcoal canister (gas tank vent) purge valve has worn out or it is plumbed wrong. This should be T fitted to the pcv line behind the carb. To test, pinch it shut at idle and the idle shouldn't change.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Unread 04-04-2014, 02:42 PM   #5
rjf1978
Thanks for the info everyone. I moved the Pcv valve to the front hole. It does rattle. As it turns out the Pcv valve was not seated properly. I'm just trying to figure out lots of things on this jeep because the PO took off all the emissions stuff. Hoping some of you will chime in on what's been done or hasn't been done. Pictures to follow. Thanks.
Unread 04-04-2014, 02:49 PM   #6
rjf1978
Pics
Unread 04-04-2014, 03:58 PM   #7
Tigerjeep79
Tigerjeep79's Avatar
1979 CJ7
Those little Cal Custom air cleaners annoy me. They don't help performance any, and there's no way to plumb the breather hole in the valve cover to the air cleaner like the factory did. You'd probably be happier with the factory type.
Tigerjeep79 is offline   Reply With Quote
