Paul's 1984 CJ-7 Build Thread - Page 72 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Paul's 1984 CJ-7 Build Thread
Unread 04-30-2014, 08:54 PM   #1066
Skerr
Jiminy that came out well, Paul. Unbelieveable! And the zip-tie trick... just stick a straight piece up in there? I am so GLAD you shared that.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 04-30-2014, 09:16 PM   #1067
Jim1611
Jim1611's Avatar
Paul the headlight buckets look nice and so does the sheetmetal work. Glad to see you working at it!
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 04-30-2014, 10:35 PM   #1068
chrisdj1992
Subscribing I love these kind of builds
chrisdj1992 is offline   Reply With Quote Quick reply to this message
Unread 05-03-2014, 08:48 AM   #1069
VACJ7
Hockey Rules!
VACJ7's Avatar
Yeah man.... I was surprised how well it worked.
It is a beautiful spring day here in northern Virginia! Headed out to the garage to get some things done.... I feel some motivation coming on.....
'84 CJ-7 | REBUILD IN PROGRESS
VACJ7 is offline   Reply With Quote Quick reply to this message
Unread 05-03-2014, 09:18 PM   #1070
VACJ7
Hockey Rules!
VACJ7's Avatar
Spent the day sand blasting, painting and powdercoating. Can't wait till I have nothing left to blast. Hours of blasting and 10 minutes of powdercaoting is annoying!! Guess I could buy a better blaster. Maybe some day. Bigger pieces I am just gonna outsource. Nothing spectacular to see but everyone loves pics so here are a couple. May put the tub on its side tomorrow and finish removing undercoating.
Unread 05-10-2014, 03:13 PM   #1071
VACJ7
Hockey Rules!
VACJ7's Avatar
Finished stripping the undercoating off the YJ tub. Used a needle scaler and it worked well. Just very time consuming but less of a mess than aircraft stripper. Ready to send it off to the media blaster. I noticed a few pin holes in some of my repairs but I will fill those when it comes back from blasting.
Unread 05-10-2014, 04:09 PM   #1072
Jim1611
Jim1611's Avatar
Your parts are looking great Paul. I know what you mean about the sandblasting. I did buy a good blast cabinet that has the pressurized tank and can tell you it works better than I could have imagined it would. Tub bottom turned out clean too.
My build thread
Unread 05-11-2014, 08:59 AM   #1073
VACJ7
Hockey Rules!
VACJ7's Avatar
Thanks Jim! I think I am going to drop the tub on the rolling chassis today and test fit things. This alone will be a challenge. I have a chain hoist connected to a steel I-beam through the garage that I use to lift the tub. Need to empty the garage and see if I have enough room to spin the chassis 180* to drop it on.
Unread 05-11-2014, 02:37 PM   #1074
VACJ7
Hockey Rules!
VACJ7's Avatar
Tub test fit....
