Paul's 1984 CJ-7 Build Thread - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Paul's 1984 CJ-7 Build Thread
Income tax season is upon us. We got what u needRough Country Lift Kits and Parts!Ruffstuff 10 year sale
Unread 10-01-2011, 03:46 PM   #91
243
1978 FSJ Cherokee
Paul, I spoke to Barry at SPI and he said *do not worry* about flash rust, the epoxy will encapsulate it and it will be fine. That is one thing I like about SPI, they deal strictly with primer and clear and thats it.
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 10-01-2011, 04:03 PM   #92
FLynes
FLynes's Avatar
1976 CJ5
Paul, you're doing an awesome job! It looks like I'm about a month behind you on my project, which is good, because I can learn about what worked for you and what didn't.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
Grammar Test
FLynes is offline   Reply With Quote Quick reply to this message
Unread 10-01-2011, 05:02 PM   #93
VACJ7
Hockey Rules!
VACJ7's Avatar
That's a relief!!! Thanks Dave.
Thanks Fred. We are probably at the same stage because I have not torn down my CJ yet. Once I get the spare frame prep'd I'll start on that.... and I am slow...
Had some leftover 2x4s from a basement project so decided to use them to build a stand for painting. Have not dropped it on yet, but think it will hold up fine.
'84 CJ-7 | REBUILD IN PROGRESS
VACJ7 is offline   Reply With Quote Quick reply to this message
Unread 10-01-2011, 05:06 PM   #94
Falcon_CMH
It might be tough to get to the inside of the frame with that setup maybe hanging the frame to paint it might be easier? I see shops do that all the time on stuff they paint they hang it for easy access to everything and with the holes in the frame you won't have anything touching the hangers so you have full access without the frame touching things.
Bought a 1980 CJ-7 that I am rebuilding ground up: http://www.jeepforum.com/forum/f8/my...thread-1264945
Given 6 hours to chop down a cherry tree a famous person once said I would sharpen my axe for 5 hours.
Falcon_CMH is offline   Reply With Quote Quick reply to this message
Unread 10-01-2011, 05:07 PM   #95
GlennLever
GlennLever's Avatar
Looks like you bled DeWalt yellow. I really like their tools
Glenn R. Lever
Rochester, New York 14617-2012
My Cars http://www.leverfamilysite.com/vehicles.htm
My restoration thread here on the Jeep forum
http://www.jeepforum.com/forum/f8/cj...build-1269301/
New FED, Drag Racing Forum (I am an Administrator) at
http://www.frontenginedragsters.org/forum/index.php
GlennLever is offline   Reply With Quote Quick reply to this message
Unread 10-01-2011, 05:09 PM   #96
GlennLever
GlennLever's Avatar
Looks like he has it set up for rotate. That should work great
Glenn R. Lever
Unread 10-01-2011, 05:12 PM   #97
Falcon_CMH
Those are some sweet tools! Not familar with the rotate being a Noob and all ! But I know your the man Glenn when it comes to that stuff.
Unread 10-01-2011, 05:18 PM   #98
VACJ7
Hockey Rules!
VACJ7's Avatar
Glenn is correct, I welded a pipe to some angle iron that will bolt on each end of the frame (stole the idea from Dave). Will be able to rotate the frame 360. After I get two coats on I will push the stands in and rest the frame on it, unbolt the angle and spray the areas covered by the angle.
I do like my DeWalt tools!! I like my new Hobart welder even more.
Unread 10-01-2011, 05:44 PM   #99
Jim1611
Jim1611's Avatar
I'm having visions of a tub rotiserie from those pictures Paul.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 10-01-2011, 06:25 PM   #100
VACJ7
Hockey Rules!
VACJ7's Avatar
You know Jim, it never crossed my mind to use them for that! I guess if I turned them around and weighted the lower crossmember with some sand bags it would probably work fine. Thanks!
Unread 10-01-2011, 06:31 PM   #101
GlennLever
GlennLever's Avatar
Will the frame clear the inside braces?
Glenn R. Lever
Unread 10-01-2011, 06:39 PM   #102
VACJ7
Hockey Rules!
VACJ7's Avatar
Yep! Rear horse is wider than the front one and each crossmember is 4" wider than the frame. And I made sure they were tall enough that nothing will catch at the bottom when I rotate it. At least that's the plan. Guess I will find out if I measured correctly once I take it for a spin.
Unread 10-01-2011, 06:45 PM   #103
FLynes
FLynes's Avatar
1976 CJ5
I like the setup, Paul. I'll be using that idea, after I get my frame repaired and sandblasted.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
Grammar Test
Unread 10-01-2011, 08:02 PM   #104
VACJ7
Hockey Rules!
VACJ7's Avatar
I think I may go out to the garage and monkey it up onto the stand. Will let you know if it collapses.
EDIT: Changed my mind. Too tired. I have a 8" steel I-beam that spans the width of my house, you can kinda see my chain hoist hanging from a 1/2" eye bolt I attached to the beam. It is offset in the garage and tomorrow AM I will rig another one in the center so I can just hoist the frame up and onto the stand. No reason to break my back when there is an easier way!!!
Unread 10-01-2011, 08:45 PM   #105
MoC
God job on the frame Paul!
MoC is offline   Reply With Quote Quick reply to this message
