Paul's 1984 CJ-7 Build Thread - Page 68 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Paul's 1984 CJ-7 Build Thread
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 09-28-2013, 10:15 AM   #1006
mistrornge
1983 CJ7
Nice fix Paul. Can't tell there is a patch there at all.
P.S. got the end caps this morning
Thank you!
Charles
1981 Jeep CJ8
1983 Jeep CJ7
I would like to say thank you to everyone for helping each other and the great posts that are a big help.
mistrornge is offline   Reply With Quote Quick reply to this message
Unread 09-28-2013, 10:17 PM   #1007
VACJ7
Hockey Rules!
VACJ7's Avatar
Originally Posted by Matt1981CJ7 View Post
Paul,
Another reason for the rotting under the roll bar pads is due to the fact that the end of the U-channel brace is open and exposed to road grime from the tires.
My solution was to tack weld a simple cap over the end of the U-channel.
Hope this helps,
Matt
Thanks Matt, I think I might do the same. My channel was packed full of crud!
'84 CJ-7 | REBUILD IN PROGRESS
VACJ7 is offline   Reply With Quote Quick reply to this message
Unread 09-28-2013, 10:18 PM   #1008
VACJ7
Hockey Rules!
VACJ7's Avatar
Thank you!
Charles
Good deal Charles. I meant to PM you to see if you received them yet.
Unread 09-28-2013, 10:27 PM   #1009
VACJ7
Hockey Rules!
VACJ7's Avatar
Got the new panel fitted up. Gap is larger than I would like in several places. Guess I will use a copper backer and fill them. Hopefully I don't blow through and make it worse.
Unread 09-29-2013, 10:19 AM   #1010
Renegade82
Renegade82's Avatar
1982 CJ7
Nice work. Your B pillar still looks to be in great shape. Yes, I would use the copper backer. I found that even cutting back the old metal to the good stuff it still has an easier tendency to blow thru. Cut a length of wood to hold it up tight to the bottom side from the floor if the magnets don't want to cooperate.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is online now   Reply With Quote Quick reply to this message
Unread 09-29-2013, 10:48 AM   #1011
VACJ7
Hockey Rules!
VACJ7's Avatar
Thanks man! I am fumbling through it. Not going to do nearly as big a patch on the other side since it does not need it. Should have done this one smaller.
Unread 09-29-2013, 12:46 PM   #1012
Renegade82
Renegade82's Avatar
1982 CJ7
Nah, the more new metal the better. Heck I added 3 spools of wire just to increase the amount! The more new metal the closer you get to a totally new tub, right?
Unread 09-29-2013, 02:37 PM   #1013
VACJ7
Hockey Rules!
VACJ7's Avatar
Welded in. At the rate I am going I should finish these three floor patches some time in 2015.
Unread 09-29-2013, 08:15 PM   #1014
Skerr
Looks like you need a little more heat, Paul. Your weld appears to be sitting on top more than blended into the tub metal. Turn up the voltage a little and weld. See what you get.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 09-29-2013, 08:30 PM   #1015
VACJ7
Hockey Rules!
VACJ7's Avatar
I got good penetration to the backside. Probably because I turned up the wire speed some since I blew through in a few spots. Once I sped up the wire that problem went away. But, as you can see a little more metal to grind.
Unread 10-05-2013, 11:34 AM   #1016
VACJ7
Hockey Rules!
VACJ7's Avatar
Did some more cutting this morning. This side went much smoother than the other. Maybe I am getting better at this. Hope to finish up by tomorrow on these patches and on to the driver floor pan. My air hose coupler sprung a massive leak so it is break time and off to Lowes.
Unread 10-05-2013, 11:59 AM   #1017
243
1978 FSJ Cherokee
Looking good Paul, when do you expect to be through with patching and starting filler?
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 10-05-2013, 02:17 PM   #1018
VACJ7
Hockey Rules!
VACJ7's Avatar
Well, realistically I probably won't be ready to send it off to the media blaster until November. And that is my problem now. I want to spray the bottom with epoxy primer and Gravitex and I am afraid it will be too cold by then. And I don't want it to sit bare metal all winter so I may opt to hold off until late March. I can use the winter to finalize and power coat all the accessories, etc. I am not going to paint the whole thing in my garage. Just the bottom and inside so I can seam seal and take it to a painter.
Unread 10-05-2013, 07:00 PM   #1019
lucdog
lucdog's Avatar
1980 CJ5
Paul, 2 1500 watt heaters can work wonders for taking the chill out of a garage. I buy 2 cheap heaters ($21each. ) every year, and get the 1 year warranty, in the spring I take them back because they stopped working) Menards, lowes, Home Depot) they run pretty much 24/7. 3 to $4 bucks a day to operate. It's just enough to keep me working.
And practice makes perfect!
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 10-05-2013, 10:25 PM   #1020
Renegade82
Renegade82's Avatar
1982 CJ7
Is that a wrangler tub? I just noticed the captured nut body mount is different, and why are there two holes? Are you going to coat that area with something before you close it up?
