Paul's 1984 CJ-7 Build Thread - Page 67 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Paul's 1984 CJ-7 Build Thread
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 09-21-2013, 10:40 AM   #991
VACJ7
Hockey Rules!
VACJ7's Avatar
Steps are done. Tried bending back in vise and quickly realized it was not gonna work. Made a relief cut, bent it back into place comparing measurements with the other step. Filled the cut with weld and probably could have left it at that. Cut a piece of 3/4 black pipe in half lengthwise and welded into place for extra support.
'84 CJ-7 | REBUILD IN PROGRESS
VACJ7 is offline   Reply With Quote Quick reply to this message
Unread 09-21-2013, 02:48 PM   #992
spward
spward's Avatar
Originally Posted by VACJ7 View Post
Does anyone have a set of OEM fenders off their Jeep that could give me a measurement or two? As you an see, the PO did some modifications to the hole where the fenders bolt to the grille. I would like to fix this. There is a seam... maybe a measurement off that seam to the center of the holes?
On my 85, they are 1/2 inch. However, there some overlap on that seam on the underside metal maybe a 1/16 or a little less. Can tell the workmanship wasn't all there.
Scott
USN Hull #227
spward is offline   Reply With Quote Quick reply to this message
Unread 09-21-2013, 03:10 PM   #993
VACJ7
Hockey Rules!
VACJ7's Avatar
Thanks Scott!
OK, I have stopped procrastinating. This was NOT fun at all but it is cut out. Have to do the same thing on the other side and the driver pan. I should have stuck with my procrastination streak. I dunno how some of you guys do this with the tub on the frame!!!!
Unread 09-21-2013, 03:57 PM   #994
243
1978 FSJ Cherokee
Did not get a lot of Jeep time this weekend. Test fitted some pieces. Need to drill holes for fender flares and rocker trim. I am commited to cutting out floor patches this week.... maybe...
Body parts are from 7 different Jeeps. Only thing original is the hood and windshield.
Paul, I hope you can appreciate the humor in this...
I was cruising east on I10 just west of downtown Houston and a mid-80's C10 was coming up on my left, I looked because I had a pretty nice C10 and you know how it is.
As he got closer I could see the fenders, hood and cab were all a different color, as he got beside me I could see the passenger side door and bed were different colors too, I was laughing and when he passed I could see the rear of the drives side of the bed was a different color as was the tailgate....and painted on the tailgate
MANUEL's USED AUTO PARTS 867-5309
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 09-21-2013, 05:28 PM   #995
Skerr
Paul... was gonna say the 5 measurements won't work, as we had to drill our own holes. The fenders would be the same as a 7, and it looks like Scott (the OTHER Scott) got them for you?? Do you need anything else?
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 09-21-2013, 05:32 PM   #996
VACJ7
Hockey Rules!
VACJ7's Avatar
Hey, my junk resembles that now! I really don't want to cut out any more floor pans.
Unread 09-21-2013, 05:33 PM   #997
VACJ7
Hockey Rules!
VACJ7's Avatar
Yeah, as a matter of fact I do.... come get my junk and return it to me in mint condition.
Unread 09-21-2013, 08:15 PM   #998
Skerr
Okay... but you gotta meet me halfway!
Kerrdog
Go Fish! <*////><
Unread 09-22-2013, 05:19 PM   #999
VACJ7
Hockey Rules!
VACJ7's Avatar
Don't buy C2Fabrication floor pan repair panels. The 2 bends that create the recessed floor section are all wrong. OEM drops like 3/8" and these bends are 1/8 at best.
Unread 09-22-2013, 06:25 PM   #1000
Renegade82
Renegade82's Avatar
1982 CJ7
The ones from Classic Enterprises were pretty spot on. I had to match my original ones. I know that doesn't help you but it's reference for other readers.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is offline   Reply With Quote Quick reply to this message
Unread 09-22-2013, 07:01 PM   #1001
VACJ7
Hockey Rules!
VACJ7's Avatar
Yeah, hopefully someone benefits from this. The bends are not even rolled like the OEM panels. In hindsight I probably could have made it work if I had not cut past the bend. Oh well, live and learn. Not really enjoying this part of the repair but is necessary. I will get through it eventually.
Unread 09-22-2013, 09:09 PM   #1002
S76
Paul. Just read up all of your thread in the past 2 days. What mad skills and patience you have! I learned allot from your thread and saved many pictures of things I haven't gotten to yet that will really help.
I just got my tub off today and will soon be practicing the fine art of procrastination as it is much "worserer" than I thought.
Thanks and keep pressing on.
If you always do what you've always done. You will always get what you've always got.
S76 is offline   Reply With Quote Quick reply to this message
Unread 09-28-2013, 08:55 AM   #1003
gazzo
Noted, thanks.
Gary (gazzo)
http://www.jeepforum.com/forum/f8/gazzos-cj10-truck-2185617/
gazzo is offline   Reply With Quote Quick reply to this message
Unread 09-28-2013, 09:31 AM   #1004
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I think that the ribs under the roll bar pads contribute to the rotting, since they allow moisture and dirt underneath the pads.
I suppose they could be seam-sealed, but I chose to use a flat piece of sheet metal under mine.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 09-28-2013, 09:48 AM   #1005
Matt1981CJ7
1981 CJ7
Paul,
Another reason for the rotting under the roll bar pads is due to the fact that the end of the U-channel brace is open and exposed to road grime from the tires.
My solution was to tack weld a simple cap over the end of the U-channel.
Hope this helps,
Matt
