Paul's 1984 CJ-7 Build Thread - Page 65 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Paul's 1984 CJ-7 Build Thread
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 07-26-2013, 10:33 AM   #961
VACJ7
Hockey Rules!
VACJ7's Avatar
They are Gen-Right Off Road 2pc "long" hood louver set.
OK, sounds like the concensus is to leave the hood alone! Thanks guys.
'84 CJ-7 | REBUILD IN PROGRESS
VACJ7 is offline   Reply With Quote Quick reply to this message
Unread 08-31-2013, 09:56 PM   #962
VACJ7
Hockey Rules!
VACJ7's Avatar
I think I have finally become motivated to get this project done. Welded up holes in the windshield frame, did some hammer and dolly work on the grill and weld up some cracks. Those two are done and ready for media blasting. Plan to finish up the tailgate, hood and fenders tomorrow and then onto the tub patches that I have been procrastinating on. Nothing really to show with pics right now. but there is progress again!
Unread 09-01-2013, 12:24 AM   #963
MoC
Get er done P!
MoC is offline   Reply With Quote Quick reply to this message
Unread 09-01-2013, 08:21 AM   #964
gazzo
Good on ya mate!
Gary (gazzo)
http://www.jeepforum.com/forum/f8/gazzos-cj10-truck-2185617/
gazzo is offline   Reply With Quote Quick reply to this message
Unread 09-01-2013, 04:37 PM   #965
Skerr
pics or yur lyin...
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 09-01-2013, 06:02 PM   #966
VACJ7
Hockey Rules!
VACJ7's Avatar
Found a few more cracks to fix on the grill so knocked that out after church. Fixed a few dents on the tailgate and then moved on to modifying my YJ tub to accept the CJ tailgate. Used weld cage nuts from McMaster. I like these, plenty of adjustability with them and they center themselves in the hole you drill. Tailgate mounted. This evening I will weld on the support brackets I swiped from my old tub.
Unread 09-01-2013, 06:57 PM   #967
243
1978 FSJ Cherokee
Way to go Paul, proud of ya dude
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 09-01-2013, 07:05 PM   #968
VACJ7
Hockey Rules!
VACJ7's Avatar
Thanks Dave, feels good to be back at it! I need to start looking for someone to paint this. I just don't have the time or room to try it in the garage. I may be insane for doing this, but I plan to assemble the body and all interior and exterial items to make sure I do not have to cut or drill once it is painted.
I am getting close to taking it all to the media blaster and I do not want it bare metal in my garage very long. When it returns from blasting I will epoxy prime the botton and spray Gravitex in the garage. But then I need to get it to a painter. I contemplated epoxy priming everything but figured if something went wrong with that first coat, the final paint may be affected.
Unread 09-01-2013, 09:04 PM   #969
Skerr
I'm with Dave. Dang nice work, Paul. Can you post a part number?
Kerrdog
Go Fish! <*////><
Unread 09-01-2013, 10:31 PM   #970
VACJ7
Hockey Rules!
VACJ7's Avatar
Thanks Scott. Part number for what?
Unread 09-02-2013, 01:39 PM   #971
VACJ7
Hockey Rules!
VACJ7's Avatar
Small step backwards this morning. Noticed one of the nuts for the tailgate latch was crooked so I figured I could thread a bolt into it and tap it straight. I am sure you can guess what happened next and the pictures tell the story of the repair.
Unread 09-02-2013, 03:04 PM   #972
Jim1611
Jim1611's Avatar
Paul the epoxy primer is the way to go. What I used had a 3 day window. Yours may be different. If it were me I'd shoot it all with the epoxy then spray the top with something like a high build primer then it's easy to sand but you still have the epoxy base. I think you'd be doing yourself a disservice by not using epoxy. Also don't leave any of it in primer for long, especially in this weather. Primer can absorb water.
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 09-02-2013, 09:22 PM   #973
Skerr
The nut inserts...
And you are welding like a pro! Well done, Lad.
Kerrdog
Go Fish! <*////><
Unread 09-02-2013, 10:36 PM   #974
VACJ7
Hockey Rules!
VACJ7's Avatar
Ah... just search "weld nuts" on mcmaster.com. Will be at the bottom of the page. Part number depends on threads.
Thanks man... Welding is improving but I still tend to "over weld" and stay in one place too long.
Unread 09-10-2013, 09:30 PM   #975
VACJ7
Hockey Rules!
VACJ7's Avatar
Started digging out crap to test fit on the YJ tub this evening. For those following along, yes, I am still procrastinating the floor pan repairs. Maybe if I wait long enough someone will get annoyed and drive up here and do it for me.
Got a nice set of rocker trim from my buddy last year. The factory bolts are toast and everyone of them is rusted in place. Interestingly none of them are in the same location horizontally when I lay them side by side. I will pick one and use it for reference to drill the tub. I can say with certainty that the holes should be 5/8" from the bottom of the tub.
