Paul's 1984 CJ-7 Build Thread - Page 59 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Paul's 1984 CJ-7 Build Thread
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 09-23-2012, 07:08 PM   #871
VACJ7
Hockey Rules!
VACJ7's Avatar
That is a Logan dash. Had it for a few yrs now.
'84 CJ-7 | REBUILD IN PROGRESS
VACJ7 is offline   Reply With Quote Quick reply to this message
Unread 09-23-2012, 07:16 PM   #872
VACJ7
Hockey Rules!
VACJ7's Avatar
Originally Posted by Jim1611 View Post
Might be easiest to move the 4 nuts Paul. What you just did is next on my tub. Nice work by the way!
It's actually 6 now. But they are all off the same amount. If I bend the cowl piece up about 3/16" they will all align because the ones with bolts in them now will move with the cowl as I bend it.
But that does not compute since the top piece ends where I cut it will no longer be flush. I dunno....
Unread 09-23-2012, 07:41 PM   #873
Renegade82
1982 CJ7
Originally Posted by rixcj View Post
The gas in the tank doesn't cool down the weld. It blankets the arc's atmosphere from oxygen. It removes the oxygen, which will contaminate the molten puddle.
When the tank is "empty" of gas, your welds will start getting porosity.
Rich
Yes, I understand what it does. But does it loose all the argon while still having Co2 left? Because the tank still has pressure in it if I just open the valve. And when the regulator is hooked up the regulator allows me to adjust pressure and will stay about 20, where I have it set, but the tank pressure shows zero.
The stranger thing is that I just tried welding again before I took the tank to be exchanged, and it seemed okay. Now I'm baffled.
I wouldn't think I'd go thru that much gas that quickly, but I don't know, hence my question to you guys.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is offline   Reply With Quote Quick reply to this message
Unread 09-23-2012, 07:59 PM   #874
VACJ7
Hockey Rules!
VACJ7's Avatar
I don't weld a ton or every day but my tank is smaller, about 2' tall, and I got it last fall. It is showing 1500 psi on the main gauge so after a yr it still has plenty of gas. Wonder if you have a leak at the regulator?
Unread 09-23-2012, 09:26 PM   #875
rixcj
rixcj's Avatar
1979 CJ5
The argon and CO2 are mixed together. I don't believe that it's possible to run out of argon, and still have some CO2 remaining.
So...if you have the tank valve completely closed (overnight, let's say...), then you open the valve, the tank pressure gauge needle doesn't move at all? Not even the slightest bit?
And yet, you can still set the gas flow at 20 cfh? If so, I would say that your tank pressure gauge is not exactly accurate ( kinda like stock CJ gauges...).
To check to see if you have a gas leak, you could mix up a few drops of liquid dish soap with some water in a spray bottle. Open your bottle gauge valve, and check all the connections with the soapy water mix. Look for bubbles...
You should get quite a bit of welding out of a tank of gas, providing that there are no leaks. My guess is that your tank pressure gauge isn't accurate, and that you have more gas in the tank than that gauge shows.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline   Reply With Quote Quick reply to this message
Unread 09-23-2012, 09:44 PM   #876
lucdog
lucdog's Avatar
1980 CJ5
20 CFM is higher than you need, I run mine at 13 CFM. Never had a problem.
Courious what brand of welder/guages?
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 09-24-2012, 11:03 AM   #877
Renegade82
1982 CJ7
Well that may be the problem. It's a Northern Tool 135 welder and regulator. I didn't try a soapy water mix but I will tonight. I may even pick up a Hobart regulator at TSupply on the way home. You guys are confirming my suspicions that I should get much more welding from a tank. Thanks
Unread 09-24-2012, 11:10 AM   #878
Dadamsnv
1977 CJ5
Windex makes for an awesome leak detector. Spray it on an watch it foam!
Cheers!
Dadamsnv is offline   Reply With Quote Quick reply to this message
Unread 09-24-2012, 09:18 PM   #879
Skerr
Windex fixes anything!
Sexy dash Paul!
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 09-24-2012, 09:22 PM   #880
lucdog
lucdog's Avatar
1980 CJ5
Apparently you haven't taken a shower in it yet. ROLF
Lucdog!
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 09-24-2012, 09:24 PM   #881
Skerr
Lucdog!
Not sure I want to hear those details, Bill, and who the heck is Rolf!?
Kerrdog
Go Fish! <*////><
Unread 09-24-2012, 09:57 PM   #882
lucdog
lucdog's Avatar
1980 CJ5
Hey my thumbs are tired from smart phone typing , ROFL
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 09-25-2012, 06:48 AM   #883
gazzo
Rolf Harris, "the Boy from Bassendean" just up the road from me. He's the guy who painted secenery pictures using only rollers and giant house paint brushes. He also painted a portrait of the Queen (of England). That must be who hes talking about. Very famous. Sang a sondg called "Tie me kangaroo down sport".
Whatever.
Gary (gazzo)
http://www.jeepforum.com/forum/f8/gazzos-cj10-truck-2185617/
gazzo is offline   Reply With Quote Quick reply to this message
Unread 09-25-2012, 08:32 AM   #884
Skerr
Whatever.
Hum a few bars, Gazzo, and I'll see if I can pick it up!
Kerrdog
Go Fish! <*////><
Unread 09-25-2012, 09:25 AM   #885
Renegade82
1982 CJ7
Tried the windex and found no leaks. Called up Northern Tool and a new regulator is on the way. Thanks again guys.
And for your listening pleasure....
