Paul's 1984 CJ-7 Build Thread - Page 7 - JeepForum.com
 2Likes
post #91 of 1107 Old 10-01-2011, 02:46 PM
243
1978 FSJ Cherokee
Paul, I spoke to Barry at SPI and he said *do not worry* about flash rust, the epoxy will encapsulate it and it will be fine. That is one thing I like about SPI, they deal strictly with primer and clear and thats it.
Dave's 78 Build
243 is offline
post #92 of 1107 Old 10-01-2011, 03:03 PM
FLynes
1976 CJ5
Paul, you're doing an awesome job! It looks like I'm about a month behind you on my project, which is good, because I can learn about what worked for you and what didn't.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is online now
post #93 of 1107 Old 10-01-2011, 04:02 PM Thread Starter
VACJ7
VACJ7's Avatar
That's a relief!!! Thanks Dave.
Thanks Fred. We are probably at the same stage because I have not torn down my CJ yet. Once I get the spare frame prep'd I'll start on that.... and I am slow...
Had some leftover 2x4s from a basement project so decided to use them to build a stand for painting. Have not dropped it on yet, but think it will hold up fine.
'84 CJ-7 |
VACJ7 is offline
post #94 of 1107 Old 10-01-2011, 04:06 PM
Falcon_CMH
It might be tough to get to the inside of the frame with that setup maybe hanging the frame to paint it might be easier? I see shops do that all the time on stuff they paint they hang it for easy access to everything and with the holes in the frame you won't have anything touching the hangers so you have full access without the frame touching things.
Bought a 1980 CJ-7 that I am rebuilding ground up:
Given 6 hours to chop down a cherry tree a famous person once said I would sharpen my axe for 5 hours.
Falcon_CMH is offline
post #95 of 1107 Old 10-01-2011, 04:07 PM
GlennLever
GlennLever's Avatar
Looks like you bled DeWalt yellow. I really like their tools
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #96 of 1107 Old 10-01-2011, 04:09 PM
GlennLever
GlennLever's Avatar
Looks like he has it set up for rotate. That should work great
Glenn R. Lever
My Web Site
post #97 of 1107 Old 10-01-2011, 04:12 PM
Falcon_CMH
Those are some sweet tools! Not familar with the rotate being a Noob and all ! But I know your the man Glenn when it comes to that stuff.
post #98 of 1107 Old 10-01-2011, 04:18 PM Thread Starter
VACJ7
VACJ7's Avatar
Glenn is correct, I welded a pipe to some angle iron that will bolt on each end of the frame (stole the idea from Dave). Will be able to rotate the frame 360. After I get two coats on I will push the stands in and rest the frame on it, unbolt the angle and spray the areas covered by the angle.
I do like my DeWalt tools!! I like my new Hobart welder even more.
'84 CJ-7 |
VACJ7 is offline
post #99 of 1107 Old 10-01-2011, 04:44 PM
Jim1611
Jim1611's Avatar
I'm having visions of a tub rotiserie from those pictures Paul.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #100 of 1107 Old 10-01-2011, 05:25 PM Thread Starter
VACJ7
VACJ7's Avatar
You know Jim, it never crossed my mind to use them for that! I guess if I turned them around and weighted the lower crossmember with some sand bags it would probably work fine. Thanks!
'84 CJ-7 |
VACJ7 is offline
post #101 of 1107 Old 10-01-2011, 05:31 PM
GlennLever
GlennLever's Avatar
Will the frame clear the inside braces?
Glenn R. Lever
My Web Site
post #102 of 1107 Old 10-01-2011, 05:39 PM Thread Starter
VACJ7
VACJ7's Avatar
Yep! Rear horse is wider than the front one and each crossmember is 4" wider than the frame. And I made sure they were tall enough that nothing will catch at the bottom when I rotate it. At least that's the plan. Guess I will find out if I measured correctly once I take it for a spin.
'84 CJ-7 |
VACJ7 is offline
post #103 of 1107 Old 10-01-2011, 05:45 PM
FLynes
1976 CJ5
I like the setup, Paul. I'll be using that idea, after I get my frame repaired and sandblasted.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
post #104 of 1107 Old 10-01-2011, 07:02 PM Thread Starter
VACJ7
VACJ7's Avatar
I think I may go out to the garage and monkey it up onto the stand. Will let you know if it collapses.
EDIT: Changed my mind. Too tired. I have a 8" steel I-beam that spans the width of my house, you can kinda see my chain hoist hanging from a 1/2" eye bolt I attached to the beam. It is offset in the garage and tomorrow AM I will rig another one in the center so I can just hoist the frame up and onto the stand. No reason to break my back when there is an easier way!!!
'84 CJ-7 |
VACJ7 is offline
post #105 of 1107 Old 10-01-2011, 07:45 PM
MoC
God job on the frame Paul!
MoC is offline
86 CJ Build Thread JimNut Jeep CJ Forum 18 07-03-2012 06:54 AM
'78 CJ5 Build Thread ggerdsen Jeep CJ Forum 26 01-31-2011 08:53 AM
Pictures of my 1984 CJ-7 Build Tigger01 Jeep CJ Forum 2 03-08-2009 10:31 AM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
