Paul's 1984 CJ-7 Build Thread - Page 68 - JeepForum.com
 2Likes
post #1006 of 1107 Old 09-28-2013, 09:15 AM
mistrornge
1983 CJ7
Nice fix Paul. Can't tell there is a patch there at all.
P.S. got the end caps this morning
Thank you!
Charles
1981 Jeep CJ8
1983 Jeep CJ7
I would like to say thank you to everyone for helping each other and the great posts that are a big help.
mistrornge is offline
post #1007 of 1107 Old 09-28-2013, 09:17 PM Thread Starter
VACJ7
VACJ7's Avatar
Originally Posted by Matt1981CJ7 View Post
Paul,
Another reason for the rotting under the roll bar pads is due to the fact that the end of the U-channel brace is open and exposed to road grime from the tires.
My solution was to tack weld a simple cap over the end of the U-channel.
Hope this helps,
Matt
Thanks Matt, I think I might do the same. My channel was packed full of crud!
'84 CJ-7 |
VACJ7 is offline
post #1008 of 1107 Old 09-28-2013, 09:18 PM Thread Starter
VACJ7
VACJ7's Avatar
Thank you!
Charles
Good deal Charles. I meant to PM you to see if you received them yet.
'84 CJ-7 |
VACJ7 is offline
post #1009 of 1107 Old 09-28-2013, 09:27 PM Thread Starter
VACJ7
VACJ7's Avatar
Got the new panel fitted up. Gap is larger than I would like in several places. Guess I will use a copper backer and fill them. Hopefully I don't blow through and make it worse.
'84 CJ-7 |
VACJ7 is offline
post #1010 of 1107 Old 09-29-2013, 09:19 AM
Renegade82
1982 CJ7
Nice work. Your B pillar still looks to be in great shape. Yes, I would use the copper backer. I found that even cutting back the old metal to the good stuff it still has an easier tendency to blow thru. Cut a length of wood to hold it up tight to the bottom side from the floor if the magnets don't want to cooperate.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is online now
post #1011 of 1107 Old 09-29-2013, 09:48 AM Thread Starter
VACJ7
VACJ7's Avatar
Thanks man! I am fumbling through it. Not going to do nearly as big a patch on the other side since it does not need it. Should have done this one smaller.
'84 CJ-7 |
VACJ7 is offline
post #1012 of 1107 Old 09-29-2013, 11:46 AM
Renegade82
1982 CJ7
Nah, the more new metal the better. Heck I added 3 spools of wire just to increase the amount! The more new metal the closer you get to a totally new tub, right?
post #1013 of 1107 Old 09-29-2013, 01:37 PM Thread Starter
VACJ7
VACJ7's Avatar
Welded in. At the rate I am going I should finish these three floor patches some time in 2015.
'84 CJ-7 |
VACJ7 is offline
post #1014 of 1107 Old 09-29-2013, 07:15 PM
Skerr
Looks like you need a little more heat, Paul. Your weld appears to be sitting on top more than blended into the tub metal. Turn up the voltage a little and weld. See what you get.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #1015 of 1107 Old 09-29-2013, 07:30 PM Thread Starter
VACJ7
VACJ7's Avatar
I got good penetration to the backside. Probably because I turned up the wire speed some since I blew through in a few spots. Once I sped up the wire that problem went away. But, as you can see a little more metal to grind.
'84 CJ-7 |
VACJ7 is offline
post #1016 of 1107 Old 10-05-2013, 10:34 AM Thread Starter
VACJ7
VACJ7's Avatar
Did some more cutting this morning. This side went much smoother than the other. Maybe I am getting better at this. Hope to finish up by tomorrow on these patches and on to the driver floor pan. My air hose coupler sprung a massive leak so it is break time and off to Lowes.
'84 CJ-7 |
VACJ7 is offline
post #1017 of 1107 Old 10-05-2013, 10:59 AM
243
1978 FSJ Cherokee
Looking good Paul, when do you expect to be through with patching and starting filler?
Dave's 78 Build
243 is offline
post #1018 of 1107 Old 10-05-2013, 01:17 PM Thread Starter
VACJ7
VACJ7's Avatar
Well, realistically I probably won't be ready to send it off to the media blaster until November. And that is my problem now. I want to spray the bottom with epoxy primer and Gravitex and I am afraid it will be too cold by then. And I don't want it to sit bare metal all winter so I may opt to hold off until late March. I can use the winter to finalize and power coat all the accessories, etc. I am not going to paint the whole thing in my garage. Just the bottom and inside so I can seam seal and take it to a painter.
'84 CJ-7 |
VACJ7 is offline
post #1019 of 1107 Old 10-05-2013, 06:00 PM
lucdog
lucdog's Avatar
1980 CJ5
Paul, 2 1500 watt heaters can work wonders for taking the chill out of a garage. I buy 2 cheap heaters ($21each. ) every year, and get the 1 year warranty, in the spring I take them back because they stopped working) Menards, lowes, Home Depot) they run pretty much 24/7. 3 to $4 bucks a day to operate. It's just enough to keep me working.
And practice makes perfect!
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #1020 of 1107 Old 10-05-2013, 09:25 PM
Renegade82
1982 CJ7
Is that a wrangler tub? I just noticed the captured nut body mount is different, and why are there two holes? Are you going to coat that area with something before you close it up?
86 CJ Build Thread JimNut Jeep CJ Forum 18 07-03-2012 06:54 AM
'78 CJ5 Build Thread ggerdsen Jeep CJ Forum 26 01-31-2011 08:53 AM
Pictures of my 1984 CJ-7 Build Tigger01 Jeep CJ Forum 2 03-08-2009 10:31 AM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
