Paul's 1984 CJ-7 Build Thread - Page 59 - JeepForum.com
 2Likes
post #871 of 1107 Old 09-23-2012, 06:08 PM Thread Starter
VACJ7
VACJ7's Avatar
That is a Logan dash. Had it for a few yrs now.
'84 CJ-7 |
VACJ7 is offline
post #872 of 1107 Old 09-23-2012, 06:16 PM Thread Starter
VACJ7
VACJ7's Avatar
Originally Posted by Jim1611 View Post
Might be easiest to move the 4 nuts Paul. What you just did is next on my tub. Nice work by the way!
It's actually 6 now. But they are all off the same amount. If I bend the cowl piece up about 3/16" they will all align because the ones with bolts in them now will move with the cowl as I bend it.
But that does not compute since the top piece ends where I cut it will no longer be flush. I dunno....
'84 CJ-7 |
VACJ7 is offline
post #873 of 1107 Old 09-23-2012, 06:41 PM
Renegade82
1982 CJ7
Originally Posted by rixcj View Post
The gas in the tank doesn't cool down the weld. It blankets the arc's atmosphere from oxygen. It removes the oxygen, which will contaminate the molten puddle.
When the tank is "empty" of gas, your welds will start getting porosity.
Rich
Yes, I understand what it does. But does it loose all the argon while still having Co2 left? Because the tank still has pressure in it if I just open the valve. And when the regulator is hooked up the regulator allows me to adjust pressure and will stay about 20, where I have it set, but the tank pressure shows zero.
The stranger thing is that I just tried welding again before I took the tank to be exchanged, and it seemed okay. Now I'm baffled.
I wouldn't think I'd go thru that much gas that quickly, but I don't know, hence my question to you guys.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is online now
post #874 of 1107 Old 09-23-2012, 06:59 PM Thread Starter
VACJ7
VACJ7's Avatar
I don't weld a ton or every day but my tank is smaller, about 2' tall, and I got it last fall. It is showing 1500 psi on the main gauge so after a yr it still has plenty of gas. Wonder if you have a leak at the regulator?
'84 CJ-7 |
VACJ7 is offline
post #875 of 1107 Old 09-23-2012, 08:26 PM
rixcj
rixcj's Avatar
1979 CJ5
The argon and CO2 are mixed together. I don't believe that it's possible to run out of argon, and still have some CO2 remaining.
So...if you have the tank valve completely closed (overnight, let's say...), then you open the valve, the tank pressure gauge needle doesn't move at all? Not even the slightest bit?
And yet, you can still set the gas flow at 20 cfh? If so, I would say that your tank pressure gauge is not exactly accurate ( kinda like stock CJ gauges...).
To check to see if you have a gas leak, you could mix up a few drops of liquid dish soap with some water in a spray bottle. Open your bottle gauge valve, and check all the connections with the soapy water mix. Look for bubbles...
You should get quite a bit of welding out of a tank of gas, providing that there are no leaks. My guess is that your tank pressure gauge isn't accurate, and that you have more gas in the tank than that gauge shows.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #876 of 1107 Old 09-23-2012, 08:44 PM
lucdog
lucdog's Avatar
1980 CJ5
20 CFM is higher than you need, I run mine at 13 CFM. Never had a problem.
Courious what brand of welder/guages?
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #877 of 1107 Old 09-24-2012, 10:03 AM
Renegade82
1982 CJ7
Well that may be the problem. It's a Northern Tool 135 welder and regulator. I didn't try a soapy water mix but I will tonight. I may even pick up a Hobart regulator at TSupply on the way home. You guys are confirming my suspicions that I should get much more welding from a tank. Thanks
post #878 of 1107 Old 09-24-2012, 10:10 AM
Dadamsnv
1977 CJ5
Windex makes for an awesome leak detector. Spray it on an watch it foam!
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #879 of 1107 Old 09-24-2012, 08:18 PM
Skerr
Windex fixes anything!
Sexy dash Paul!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #880 of 1107 Old 09-24-2012, 08:22 PM
lucdog
lucdog's Avatar
1980 CJ5
Apparently you haven't taken a shower in it yet. ROLF
Lucdog!
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #881 of 1107 Old 09-24-2012, 08:24 PM
Skerr
Lucdog!
Not sure I want to hear those details, Bill, and who the heck is Rolf!?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #882 of 1107 Old 09-24-2012, 08:57 PM
lucdog
lucdog's Avatar
1980 CJ5
Hey my thumbs are tired from smart phone typing , ROFL
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #883 of 1107 Old 09-25-2012, 05:48 AM
gazzo
Rolf Harris, "the Boy from Bassendean" just up the road from me. He's the guy who painted secenery pictures using only rollers and giant house paint brushes. He also painted a portrait of the Queen (of England). That must be who hes talking about. Very famous. Sang a sondg called "Tie me kangaroo down sport".
Whatever.
Gary (gazzo)
http://www.jeepforum.com/forum/f8/gazzos-cj10-truck-2185617/
gazzo is offline
post #884 of 1107 Old 09-25-2012, 07:32 AM
Skerr
Whatever.
Hum a few bars, Gazzo, and I'll see if I can pick it up!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #885 of 1107 Old 09-25-2012, 08:25 AM
Renegade82
1982 CJ7
Tried the windex and found no leaks. Called up Northern Tool and a new regulator is on the way. Thanks again guys.
And for your listening pleasure....
86 CJ Build Thread JimNut Jeep CJ Forum 18 07-03-2012 06:54 AM
'78 CJ5 Build Thread ggerdsen Jeep CJ Forum 26 01-31-2011 08:53 AM
Pictures of my 1984 CJ-7 Build Tigger01 Jeep CJ Forum 2 03-08-2009 10:31 AM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
