Paul's 1984 CJ-7 Build Thread - Page 17 - JeepForum.com
 2Likes
post #241 of 1107 Old 01-15-2012, 09:37 PM
honda250ex
1987 YJ Wrangler
Nice man
It's better to live one day as a lion than a hundred years as a lamb.
http://www.jeepforum.com/forum/f12/honda250exs-buildup-860712/
honda250ex is offline
post #242 of 1107 Old 01-21-2012, 04:30 PM Thread Starter
VACJ7
VACJ7's Avatar
Not much left....
'84 CJ-7 |
VACJ7 is offline
post #243 of 1107 Old 01-21-2012, 05:19 PM
Skerr
What... did you do something? Your shop's a mess!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #244 of 1107 Old 01-21-2012, 08:21 PM Thread Starter
VACJ7
VACJ7's Avatar
This may appear to be an illusion of the camera, but I assure you it is not. Look at the frame vs axle angle and you can see how bent this thing is! It starts to bend out about where the arrow is pointing.
'84 CJ-7 |
VACJ7 is offline
post #245 of 1107 Old 01-21-2012, 10:06 PM
jakeryii
1967 CJ5
doin good man were are u in va? im in the north end of Chesterfield (south-side of Richmond)
94 ZJ 4.0, np 249 on 31x10.50s no lift
jakeryii is offline
post #246 of 1107 Old 01-22-2012, 07:07 PM Thread Starter
VACJ7
VACJ7's Avatar
Thanks! I am further north in the Alexandria area.
Not much progress today. Removed rear bumper, dropped gas tank and drained fluids from engine, trans, TC and axles. Removed brake and fuel lines. Hoping this week I will be done with the tear down. Stopping to take pictures of everything and bagging is slow work.
My goal before Spring gets here is re-gear the Dana 30 and get everything into a rolling chassis. I have aready rebuilt the AMC20 and the Dana 30. Engine is ready to go in and I also previously rebuilt the TF999 and Dana 300. I think I am on track.
'84 CJ-7 |
VACJ7 is offline
post #247 of 1107 Old 01-22-2012, 07:37 PM
Skerr
Paul, when I towed our Jeep home with the towbar, it was constantly trying pass me on the left side. I had to hug the right line to keep the Jeep inside the center line. If you remember our thread from way back, we had frame issues too. Measure your diagonals and see how far out of whack you are. It cost me $100 to straighten our frame. And I'm willing to BET you can do it by yourself! Don't be discouraged, and don't go buy another frame... yet!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #248 of 1107 Old 01-28-2012, 03:58 PM Thread Starter
VACJ7
VACJ7's Avatar
I wanted to finish the tear down today but ran out of steam. Almost there. I won't go into the stupid details, but when I was removing the rear axle I thought I had a grand idea to do it very easily. Turns out the frame makes a great seesaw when you leave the front axle in and support the frame in the wrong place. Had the garage door up and almost ended up with the rear end of the frame embedded in the door.
Scott, as you can see in the background I'm not worried about the frame.
'84 CJ-7 |
VACJ7 is offline
post #249 of 1107 Old 01-28-2012, 05:27 PM
Jim1611
Jim1611's Avatar
Nice to see you moving forward Paul.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #250 of 1107 Old 01-28-2012, 05:30 PM
Jim1611
Jim1611's Avatar
I posted earlier and then noticed this thread isn't rated and it needs to be! You're doing excellent work Paul and it needs to be recognized.
My build thread
Jim1611 is offline
post #251 of 1107 Old 01-28-2012, 08:22 PM Thread Starter
VACJ7
VACJ7's Avatar
Thanks Jim! I can't wait to start building it back up.
All 4 frame nuts for the sway bar mount spun trying to remove. Since the frame will be headed to the recycler I was thinking I would cut open the frame with my OA torch but now that I think about it I do not think there is a nut inside. I think they are just a threaded barrel inserts. Guess I will just grind the heads off.
'84 CJ-7 |
VACJ7 is offline
post #252 of 1107 Old 02-04-2012, 12:30 PM Thread Starter
VACJ7
VACJ7's Avatar
Out with the old, in with the new.
Todays project (after I watch some hockey) is to figure out where the skid needs to go for my I6/TF999 combo. Drill some holes and weld in frame nuts. I will take multiple measurements from some common points between the two frames. Also need to figure out where to drill holes for the front shock towers. Not quite sure how I will figure that one out just yet.
Got the sway bar mounts off this morning too. Forgot how much I like my OA torch! Just used it to cut the heads off the bolts.
'84 CJ-7 |
VACJ7 is offline
post #253 of 1107 Old 02-04-2012, 08:08 PM
contdevelop
Is that a Throttle Down Kustoms frame?
contdevelop is offline
post #254 of 1107 Old 02-04-2012, 10:45 PM Thread Starter
VACJ7
VACJ7's Avatar
No, it is a 79 CJ frame I found on craigslist is excellent condition.
'84 CJ-7 |
VACJ7 is offline
post #255 of 1107 Old 02-05-2012, 07:21 AM
243
1978 FSJ Cherokee
Paul, if I keep looking at your avatar I may have to order a ss header and hang it on the wall in my office, it sure looks nice! I thought long and hard about a Offy intake Borla header and went with a factory cast iron manifold and stock aluminum intake. After some time on the road, I may look at an intake/exhaust/4.0 head swap if the power of the stock parts and tbi do not meet my needs.
Dave's 78 Build
243 is offline
86 CJ Build Thread JimNut Jeep CJ Forum 18 07-03-2012 06:54 AM
'78 CJ5 Build Thread ggerdsen Jeep CJ Forum 26 01-31-2011 08:53 AM
Pictures of my 1984 CJ-7 Build Tigger01 Jeep CJ Forum 2 03-08-2009 10:31 AM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
