Paul's 1984 CJ-7 Build Thread - Page 16 - JeepForum.com
 2Likes
post #226 of 1107 Old 01-07-2012, 09:51 PM
lucdog
lucdog's Avatar
1980 CJ5
It does look really good in the pictures. Its amazing what PO's put behind bondo as a filler.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #227 of 1107 Old 01-09-2012, 07:46 PM Thread Starter
VACJ7
VACJ7's Avatar
Ok... so I need to get two stripped torx out of my tailgate. I know WHAT to do, just not sure HOW. Weld a nut to the torx. Do you just aim the tip inside the base of the nut and filler up? Or a series of tacks? What about welder setting? Something like for 1/8 steel?
'84 CJ-7 |
VACJ7 is offline
post #228 of 1107 Old 01-09-2012, 08:06 PM
243
1978 FSJ Cherokee
Fill it up, and settings for 1/8" sound about right to me.
Dave's 78 Build
243 is offline
post #229 of 1107 Old 01-09-2012, 08:35 PM
lucdog
lucdog's Avatar
1980 CJ5
I prefer to weld the largest washer without going past the edge of the Torx. Or a fender washer. Then weld the nut on. I've never had any luck welding that deep into a nut. A jam nut might be better.
I run my 110v Lincoln at 3/4 of Max. Its not going to do any good to fill the nut to the top. Its all about initial penatration.
On edit, I keep the weld to 1/2 the nut. This has never failed me. If you were worried about to much weld on the nut, use a coupleing nut
Bill
Bill
ForumRunner_20120109_212959.jpg   ForumRunner_20120109_213048.jpg   ForumRunner_20120109_213203.jpg
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #230 of 1107 Old 01-10-2012, 07:42 PM Thread Starter
VACJ7
VACJ7's Avatar
Thanks Dave and Bill! I set my Hobart 187 for 1/8 steel with .030 solid wire and gas. First attempt I obvious had zero penetration and twisted the nut right off the torx. All further attempts were successful and all torx removed. I used jam nuts like Bill suggested and worked very well. I didn't actually try to fill the nut... it just ended up that way after welding on two sides of the nut.
I know this is simple for most, but having never done this before there was as sense of accomplishment.
'84 CJ-7 |
VACJ7 is offline
post #231 of 1107 Old 01-10-2012, 07:46 PM
243
1978 FSJ Cherokee
Don't ya love it when stuff works as planned!
Dave's 78 Build
243 is offline
post #232 of 1107 Old 01-10-2012, 07:56 PM
lucdog
lucdog's Avatar
1980 CJ5
Cool
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #233 of 1107 Old 01-10-2012, 10:11 PM
twinstickd20
1979 CJ7
Not sure how I have managed to miss this build, I just finished a quick read through and could not seem to find what paint you used on that beautiful 258. I'm about to tear into the 258 in mine to give it a check over before I put a 4.0 head and fuel injection on it and since I'll have it out I might as well paint it. Anyways now I'm subbed so I'll be watching this one for sure.
My Build Thread
twinstickd20 is offline
post #234 of 1107 Old 01-10-2012, 10:36 PM Thread Starter
VACJ7
VACJ7's Avatar
Thanks for the compliment. Hopefully it runs as good as it looks. It is AMC Blue from Seymour http://www.seymourpaint.com/hi_tech_engine_enamels.html
'84 CJ-7 |
VACJ7 is offline
post #235 of 1107 Old 01-10-2012, 10:46 PM
twinstickd20
1979 CJ7
Thank you
My Build Thread
post #236 of 1107 Old 01-11-2012, 04:49 PM
Skerr
Hey... Good job, Paulie!!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #237 of 1107 Old 01-15-2012, 08:35 PM Thread Starter
VACJ7
VACJ7's Avatar
A little more progress. All the tub bolts are out and tub is ready to be lifted off. As soon as I can sucker my buddy to come over and help. Hopefully tomorrow. Only two refused to come out. Fixed that with the sawzall. Defrost duct metal cut out as well as the tailgate cable mounts to go over to the YJ tub. Started stripping the engine. Tub will be headed to the metal recycler. Hopefully bondo weights more than steel. At $12 per 100 lbs I should be $24 richer.
'84 CJ-7 |
VACJ7 is offline
post #238 of 1107 Old 01-15-2012, 09:08 PM
Skerr
Sheeesh, Paul. Even your tear down is clean! I have not seen anyone with a torn down Jeep that looks that neat! Shouldn't there be stuff sticking out everywhere? Is the tub literally 200 pounds?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #239 of 1107 Old 01-15-2012, 09:16 PM Thread Starter
VACJ7
VACJ7's Avatar
I think I read a post by Keith460 that a stripped CJ7 tub weights 224 lbs. I am OCD when it comes to working in the garage. Crap will be everywhere and at the end of the day I clean it all up. I am running out of room too! I wanted to turn it around on the wheel dollies but with the tub on one side and the frame on the other I will not have enough room to turn it 180. I need MoC to build me an addition!!!!
'84 CJ-7 |
VACJ7 is offline
post #240 of 1107 Old 01-15-2012, 09:27 PM
MoC
MoC is offline
86 CJ Build Thread JimNut Jeep CJ Forum 18 07-03-2012 06:54 AM
'78 CJ5 Build Thread ggerdsen Jeep CJ Forum 26 01-31-2011 08:53 AM
Pictures of my 1984 CJ-7 Build Tigger01 Jeep CJ Forum 2 03-08-2009 10:31 AM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
