Paul's 1984 CJ-7 Build Thread - Page 11 - JeepForum.com
 2Likes
post #151 of 1107 Old 10-16-2011, 02:38 PM Thread Starter
VACJ7
VACJ7's Avatar
Originally Posted by MoC View Post
Slow down Paul your making us slow pokes look bad! PM me your address again. I have something for you.
Ohhhh, is it your 360?
Wash, rinse, repeat. I think I washed it 4 times. Alternated between hot soapy water and hot diluted purple power. I forgot I picked up this engine cleaning wand at HF a few months ago but then remembered! For a couple bucks this thing is money! High pressure wash at your finger tips. The angled tip made it easy to clean hard to reach areas. I blew every thing dry with compressed air and is now drying some more in the sun.
Guy at the machine shop recommended wiping down the cylinders with marine fogging oil... which I did.
'84 CJ-7 |
VACJ7 is offline
post #152 of 1107 Old 10-16-2011, 09:12 PM Thread Starter
VACJ7
VACJ7's Avatar
Decided to send my torque wrenches out for calibration before I start assembly on the engine. Do most assemble the whole thing before painting? Kinda leaning toward taping the block up this week and get the AMC blue on it. Can do the same to the head separately. I may powder coat the oil pan.
'84 CJ-7 |
VACJ7 is offline
post #153 of 1107 Old 10-16-2011, 10:27 PM
Skerr
Going to have to get one of those wands! That's cool.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #154 of 1107 Old 10-17-2011, 10:57 AM
Renegade82
1982 CJ7
What is that, welded?, to the center freeze plug?
Interesting build so far. I'm waiting for the tear down portion. I'm about as far as you on my build (and will soon start a thread) but I started with a new frame, used the internal paint, and then POR'd the outside. Now I'm waiting for a stone mason to get done so I can finish up my last "other" project which requires the use of my tear down space in the garage. Then it's time (about 2 weeks yet). I'm rarinnn' ta go!
Renegade82 is offline
post #155 of 1107 Old 10-17-2011, 11:25 AM Thread Starter
VACJ7
VACJ7's Avatar
It is some type of identifier from the machine shop. Looks like an epoxy type putty holding it on.
'84 CJ-7 |
VACJ7 is offline
post #156 of 1107 Old 10-17-2011, 12:09 PM
243
1978 FSJ Cherokee
I believe that is to identify when the engine is overheated.
Dave's 78 Build
243 is offline
post #157 of 1107 Old 10-17-2011, 10:35 PM
rixcj
rixcj's Avatar
1979 CJ5
You're correct, Dave.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #158 of 1107 Old 10-17-2011, 10:43 PM Thread Starter
VACJ7
VACJ7's Avatar
How does it work? Changes color or something?
'84 CJ-7 |
VACJ7 is offline
post #159 of 1107 Old 10-17-2011, 10:47 PM
rixcj
rixcj's Avatar
1979 CJ5
The small medallion in the center of the freeze plug is made of a softer metal, like lead. It will melt if the engine overheats. Many engine rebuilders use these freeze plugs when they offer a warrantee. The warantee is void if you cook the engine, and this lets them know that you've overheated it.
Rich
rixcj is offline
post #160 of 1107 Old 10-18-2011, 07:15 AM
Eaglekeeper
Frame came out great! Now the real fun begins
86 CJ7, 258 Engine, T-177, Dana 300.
A ton more pics here.
Eaglekeeper is offline
post #161 of 1107 Old 10-20-2011, 08:33 PM Thread Starter
VACJ7
VACJ7's Avatar
I pulled out the oil pan that came with the engine I am rebuilding and not sure about this thing. It has no skid and no evidence that it ever had one. I placed it on the block and while most of the holes line up, all of them are not perfect. I guess I need to look for a new pan. I thought I read the OMIX and/or Crown pans had fitment issues. Anyone know?
If I can find an OEM pan that is not beat to crap I will go that route. I don't want to use the one on my running 258.... it had a hole in the side at some point that someone welded a patch over.
'84 CJ-7 |
VACJ7 is offline
post #162 of 1107 Old 10-20-2011, 08:47 PM
243
1978 FSJ Cherokee
Paul, I think you might have a better paint job if you paint the engine once it is assembled. I still don't know if I had my block and head fully-degreased. I suspect there was some oil in the cast iron pores and the paint will flake off over time. Maybe in time, I won't really care
Dave's 78 Build
243 is offline
post #163 of 1107 Old 10-29-2011, 11:30 AM Thread Starter
VACJ7
VACJ7's Avatar
Kinda stalled for the moment. Had an issue fitting cam but turned out to be a small burr that was preventing it from sliding in. Machine shop took care of it with a bearing scraper. I sent my torque wrenchs out for calibration and glad I did because they both required adjustment. I should get them back on Tuesday. Spent the morning cleaning the crank, cam and pistons. Everything is ready to go.
'84 CJ-7 |
VACJ7 is offline
post #164 of 1107 Old 10-30-2011, 03:39 PM Thread Starter
VACJ7
VACJ7's Avatar
Well, yesterday it snowed and today was sunny and kinda warm. Got tired of looking at the bare block and garage ain't gonna get warmer as the days pass so...... first light coat sprayed.
'84 CJ-7 |
VACJ7 is offline
post #165 of 1107 Old 10-30-2011, 04:07 PM
Jim1611
Jim1611's Avatar
Looking great so far Paul.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
86 CJ Build Thread JimNut Jeep CJ Forum 18 07-03-2012 06:54 AM
'78 CJ5 Build Thread ggerdsen Jeep CJ Forum 26 01-31-2011 08:53 AM
Pictures of my 1984 CJ-7 Build Tigger01 Jeep CJ Forum 2 03-08-2009 10:31 AM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
