passenger front blinker - JeepForum.com
post #1 of 5 Old 04-22-2015, 08:46 AM Thread Starter
fire788
I have a 1977 cj5 the owner before me cut the passenger front blinker wire and hooked it to a ground wire at the fire wall when it is grounded the parking light comes on and if i hook it up to the blinker wire i have blinker on the front passenger but no parking light on that light any ideas
fire788 is offline
post #2 of 5 Old 04-22-2015, 09:27 AM
texasdave
texasdave's Avatar
1980 CJ7
You have a constant ground. One wire is for parking lights one wire for blinkers or turn signals. the unit is grounded through the mounting screw that holds the lens on. They get rusty and need replacing. Also make sure your sheet metal your screwing it into is clean as well
texasdave is offline
post #3 of 5 Old 04-22-2015, 09:28 AM
1949er
Your front marker/turn light grounded through the mounting screws to the grill / to the fender / to the tub , run a separate ground to the grill also make sure you have the correct Shouldered Screws for the light lense - holds the light to the grill without breaking the lense
1949er is offline
post #4 of 5 Old 04-22-2015, 10:16 AM
gmakra
Bad Blinker fluid?
gmakra is offline
post #5 of 5 Old 04-22-2015, 10:21 AM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
I would add punctuation.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
