Parts that are know to not fit or be sub par - Page 4 - JeepForum.com
post #46 of 75 Old 11-05-2013, 09:19 AM
EgulAye
1980 CJ5
Originally Posted by keith460 View Post
NAPA. Good fit, just like OEM.
X2
Most of the NAPA stores around me will also custom make hydraulic hoses for you. The right fittings and length of your choice. Guys w/ tractors and off road equipment seem to be in there often getting a hose made up.
2012 JK
Do you wave at night when they can't see you?
EgulAye is offline
post #47 of 75 Old 11-22-2013, 09:49 AM Thread Starter
chris989604
1980 CJ7
Tailgate seal
Crown part # 5457112 Tailgate seal
40$
A
fits perfect,
http://www.jeep4x4center.com/tailgate-seal-5457112.html
chris989604 is offline
post #48 of 75 Old 11-22-2013, 12:03 PM
jetmech1
Originally Posted by chris989604 View Post
crown part # 5457112 tailgate seal
40$
a
fits perfect,
x2
jetmech1 is offline
post #49 of 75 Old 04-17-2014, 10:44 AM Thread Starter
chris989604
1980 CJ7
Best top Bikini
part# 52508
50$
graded D-
i give it the D because i did actually get it on my jeep but it looks like junk, is junk and best top as a company is junk.
Not sure why they can not make the top the same as 10 years ago when it fit like a glove but this joke is a waste of time and money. The top is cut ~one inch from the ends and snaps are placed there. The snap on mine is too close to the seam and will not allow it to fold over and slide into the track. I removed a snap hoping it would fit but because of the binding stitched at the seam it still will not go in.
When i find a good source for the plastic stiffener i will make the top myself and it will fit like it should.
post #50 of 75 Old 04-17-2014, 05:02 PM
Tigerjeep79
1979 CJ7
What a shame. Bestop used to make good stuff.
Tigerjeep79 is offline
post #51 of 75 Old 04-17-2014, 07:07 PM
248107
1983 CJ7
where to start Rugged Ridge seats
could make a book on this thread
248107 is offline
post #52 of 75 Old 04-18-2014, 02:17 PM
titomars
1981 CJ7
Best top Bikini
part# 52508
50$
graded D-
I have had and been using my Bestop Classic for 4 years now (looks identical to yours) except I left the snaps on. They did not get in the way for me. I have not had a single problem with mine. The only thing I did differently was I did not like the current 2 piece W/S rail. I had an older 1 piece rail I used instead. Also I installed 12-24 nutserts and Stainless socket head bolts then bolted the rail to the W/S frame. No sheet metal screws for me
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #53 of 75 Old 04-18-2014, 02:26 PM
CJ7ROB
Originally Posted by titomars View Post
I am having the same problem. What seal did you end up using?
Tito, sorry for the late response, but I ended up bringing my glass and the frame to a glass shop and they sourced the rubber seal, came out awesome.
CJ7ROB is offline
post #54 of 75 Old 04-18-2014, 02:31 PM
titomars
1981 CJ7
No problem. I tried 2 different manufacturers seals neither was worth a crap. One was too big and I was not about to cut it and have a gap/seam, and the other was too thick causing the glass to shatter upon install. So I ended up reusing my old seal and A tube of W/S urathane sealer.
titomars is offline
post #55 of 75 Old 04-18-2014, 02:49 PM
hicks1983
Best top Bikini part# 52508 50$ graded D- i give it the D because i did actually get it on my jeep but it looks like junk, is junk and best top as a company is junk. Not sure why they can not make the top the same as 10 years ago when it fit like a glove but this joke is a waste of time and money. The top is cut ~one inch from the ends and snaps are placed there. The snap on mine is too close to the seam and will not allow it to fold over and slide into the track. I removed a snap hoping it would fit but because of the binding stitched at the seam it still will not go in. When i find a good source for the plastic stiffener i will make the top myself and it will fit like it should.
All you need to do is cut an inch off your retaining channel on each side. Will fit fine
hicks1983 is offline
post #56 of 75 Old 04-18-2014, 02:57 PM
G-FOURce
Omix turn signal lever (#13318.07)
Garbage.
G-FOURce is offline
post #57 of 75 Old 04-18-2014, 06:45 PM
WindKnot
1977 CJ7
What about the soft top? How well does it fit after the trim?
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is online now
post #58 of 75 Old 04-19-2014, 10:45 AM Thread Starter
chris989604
1980 CJ7
Titomars,,
so you cut the track and used best tops snaps??
post #59 of 75 Old 04-19-2014, 10:47 AM Thread Starter
chris989604
1980 CJ7
I returned my top, huge disappointment. I am going to start modifying/making custom tops as soon as i get my shop set up.
here is the tread
http://www.jeepforum.com/forum/f8/ne...issue-1944297/
post #60 of 75 Old 04-19-2014, 11:56 AM
titomars
1981 CJ7
Titomars,,
No, I had an older rail from an extra windshield frame. main reason I used it over the current rail is I did not care for the 2 piece design and the one piece rail was heavier aluminum. I never cut anything the snaps land just outside the rail tips so it was a non issue for me. I'll post up a couple of photos later today.
Ohh side note my Bestop full soft top fits perfectly too. Same thing the snaps are just outside the ends of the rail.
titomars is offline
