-   -   Parking Brake Hookup Help (http://www.jeepforum.com/forum/f8/parking-brake-hookup-help-1340329/)
Hybrid Jeep 03-08-2012 08:04 PM
Hey there guys- I have a 76 CJ5 that I've been rebuilding for a while now. I'm at the stage where I want to hook up the parking brake.
Now.. I can't remember how the stock system worked.. and my pictures are doing me no good .. To make matters even more complicated - I've done a disk brake conversion using 300ZX calipers.
Take a look at this pic:
http://i178.photobucket.com/albums/w...rkingbrake.jpg
See the spring thing on the right of the caliper? This actuates the built in parking brake for the 300zx calipers.
Do I hook the cable to this? Then route it to the cab? Does it hook up somewhere along the frame? I'm thinking eye bolts maybe? Do I have to fab up a bracket so that the cable pulls at a certain angle?
ShowroomShine 03-08-2012 08:42 PM
There are 2 cables coming from right rear and left rear. They run to an equalizer in front of the rear cross member. The 2 cables connect to the equalizer and then one cable runs from that through the frame and into the cab.
Hybrid Jeep 03-09-2012 05:40 PM
Do you have a picture of this? What about eye bolts along the frame... Are there any?
Also.. how do you hook up to the 300zx parking brake? Does the cable simply loop on to it?
I know that others have done this conversion!
sherlocktk 03-09-2012 05:58 PM
3 Attachment(s)
When I did mine I made a bracket for it.
I started to use the brackets that I see you used for you brake lines, but bent it up too much and had to start over. I also made brackets to hold the brake lines just as you did. It seems no one has exactly what these little strips are for. This is what I think it is really for as its the right size (or close) depending on who you got it from
Take a 4 inch x 1 inch piece of 3/16 steel or so.
Drill a 5/8 hole as close as possible to the end of it, leaving about 3/16 material.
On the other side drill a 1 size up from 3/8 hole See Picture 1
Bend the bracket similar to the picture. It is almost totaling 90 degrees with about 20 degrees on the 3/8ish hold and the rest on the big hole this allows the parking brake to pull straight down. See Picture 2
Mount the bracket with the large hole facing down, run your parking brake cable through this hole, it should "snap" in to the 5/8 hole into the plate without issue. Make sure you cut off about 1 inch of the Spring on the parking brake, pull the spring down and thread the nut between the 2 fingers of the e-brake bracket. (See Picture 3)
I had to take the passenger brake cable to use it for the driver side and got a new cable for the passenger side I had to shorten this new cable about 1.25 inches to make the brake engage super good. That was just a 3/16 all thread coupling nut hammered flat to be the "stop"
take about 1 inch off of the parking brake spring (I had to cut mine about 10 differnt places to get the spring steel off)
If you need more pics than this let me know.
Hybrid Jeep 03-09-2012 06:45 PM
Oh man! Thank you for that! I knew someone had done this conversion.. awesome! I didn't even see the threaded hole on the caliper.
Ok.. few points of clarification. I make the bracket, and mount it to that threaded hole right? Did you put it on the "spring side" or the other side? What do you mean by the cable will "snap" in to the 3/16? Do you mean the 3/16" bracket?
Also.. what do you mean by cut 1" off the spring? I can see how to remove it.. but what is the reason for shortening the spring? Seems like it would be difficult to re-bend the hooks. Are you shortening it to make it easier to actuate?
Thanks again! If you have a pic of your setup that would really help.
sherlocktk 03-09-2012 07:14 PM
3 Attachment(s)
Here are pictures of how I did mine. Pic 1 is left side, Pic 2,3 is right side. Basically the same just reversed. The spring I shortened is the parking brake cable spring, Its 4 inches or so long, but when you put the bracket in, it will not allow the full movement if left alone. Basically my spring is 1/4 inch longer than the distance from the bracket to the clip where the cable hooks in. Basically you want to need to compress it a little to get it on there. but you want to allow enough spacing so the brake can engage all the way through the parking brake pedal travel. I really meant 5/8 not 3/16 I have edited the original post
Hybrid Jeep 03-09-2012 07:43 PM
Sherlock - you are the man! Did you have to use any eye bolts along the frame or does the cabling just hang? Thanks again for all your excellent help.
sherlocktk 03-09-2012 11:05 PM
I have the cables hung around the frame with just some 12ga copper wire twisted to hold up the cables so they don't get stuck on the driveshaft or exhaust. . Zip ties would work too. But i wanted better heat resistance but easy enough to take off in the field
CJ7ROB 01-26-2013 02:44 PM
I'm going thru this swap as we speak, this bracket fab for the e-brake cables will be a big help, thx.
titanjeep 03-10-2013 10:25 AM
Is the brake on in these pictures?
sherlocktk 03-10-2013 02:07 PM
Brake is not engaged in the pictures it articulates about 90 degrees rotated down to the floor when engaged
titanjeep 03-10-2013 02:34 PM
Thanks. If that is the case, then my cable is too short. Were you using the stock CJ7 cables, or did you buy new cables?
waterdowg 03-11-2013 08:52 AM
The stock cables should work, you just need to extend the front cable. There is some info on that here not much and mya be hard to find. I will post some more info when I have some time.
sherlocktk 03-11-2013 11:39 AM
I took off the driver side cable and threw it away. I took the passenger side cable and moved to driver side. I bought a new cable for the passenger side that was 5 inches longer or so
titanjeep 03-14-2013 12:22 AM
I look forward to the details... thanks for the assistance.
The time now is 04:11 PM.
