Parking brake drum nut size? - JeepForum.com
post #1 of 3 Old 10-29-2013, 06:37 PM Thread Starter
indikacr
1969 CJ5
Hey guys, I was wanting to do some work on the parking brake of my 69 cj5. (It has the driveshaft drum brake). After removing the 4 bolts connecting the driveshaft to drum, I see there is still a large nut that needs to be removed to access brake shoes. I need to buy this socket, since I don't have one that large. What size socket should I look for?
Thanks!
indikacr is offline
post #2 of 3 Old 10-29-2013, 07:07 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
That is the yoke nut. I believe it is 1 1/4" for the big shaft V6 D18.
If for some reason that is too large, try a 1 1/8"
You will want to use an air gun if it is accessible. Otherwise, you will need to lock up the drivetrain and attempt to remove it with a breaker bar.
Before you remove the nut, check the vertical movement of the yoke. If there is slop, be sure to reset the end play by removing a shim or two in order to tighten up the output bearings before you reassemble the parking brake.
I would plan to replace the rear output seal while I was in there.
jeepdaddy2000 is offline
post #3 of 3 Old 10-30-2013, 11:37 AM Thread Starter
indikacr
1969 CJ5
Thanks!
You learn something new every day!
indikacr is offline
