Parking Brake - JeepForum.com
post #1 of 9 Old 01-20-2008, 11:55 PM Thread Starter
kstopp
1993 XJ Cherokee
Parking Brake
My cj7 has the foot parking brake with pull cable relase, has anyone else converted this to a typical ebrake found in the wranglers coming out of the center console, racheting style. Would this be as simple as finding the assembly, mounting it and cutting the cable to fit?
kstopp is offline
post #2 of 9 Old 01-21-2008, 12:02 AM
OldSailor
1977 CJ7
I've never heard of anyone trying it.
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc.
OldSailor is offline
post #3 of 9 Old 01-21-2008, 08:29 AM
Fatman
Fatman's Avatar
2008 CJ7
Kstopp,
I'm waiting for your write up!
I've been looking to do the same thing.
Thread Links:
Fatman is offline
post #4 of 9 Old 01-21-2008, 09:06 AM
supraman1990
supraman1990's Avatar
1980 CJ5
Seems like you would just need to figure a way to route the cable to the center of the Jeep and a way to attach the lever. Levers are easy to come by, as they are assemblys.
80 CJ5 in the process of a frame up resto
96% complete.
The little stuff will kill me.
On the back burner for college.
supraman1990 is offline
post #5 of 9 Old 01-21-2008, 10:29 AM
Mike Romain
Yes, it can be done. You just get the hardware from a Cherokee or something similar and install it. The cable has two ends and a sheath so it can move around and even loop if needed while still working.
I have heard of sand runners that even use two brake handles, one for each wheel. They use that for power turns and as a poor mans locker. On an open diff, if you put the brakes to the spinning wheel, the other side moves.
Mike
Mike Romain is offline
post #6 of 9 Old 01-21-2008, 12:49 PM
CJ Chet
Lokar makes some nice assemblies.
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #7 of 9 Old 01-21-2008, 01:12 PM
81CJUSMC
1981 CJ7
I have looking for information on this as well. I have an EBrake (Foot Pedal) that is non functional and figured it would be cool to put in a hand lever instead. Seems that there are a few others with the same thoughts...Doesn't seem like it would be hard as long you can route the cable without it hanging up on something or preventing the function of the brake.
If it's that important to do on a Friday, it can wait until Monday...
81CJUSMC is offline
post #8 of 9 Old 01-21-2008, 01:23 PM
pkt1213
That's a pretty bad *** idea with using it as kind of a poor mans locker. Kinda hard on the brakes though.
This would also be nice for us all guys with CJ5s
"If it has tires or tits it'll give you trouble."
"I live with fear everyday, but occationaly she lets me go racing."
'98 Toyota 4runner SR5 - V-6, 5-speed, 4x4, new tires, stock. TRD filter
pkt1213 is offline
post #9 of 9 Old 01-21-2008, 01:31 PM
Mike Romain
I run on the trails all winter up here in Canada with my open diffs and use the brake pedal lots to 'lock up' the rear end. It is an old trick even mentioned in my CJ7's owners manual. They recommend the parking brake, I like the pedal better.
When I am sitting on ice with one front and one back wheel calmly spinning away, I can give the brake pedal a push or a solid pound if the push didn't do it while giving gas at the same time. This loads up the spinning wheel until the torque needed to go against the brake equals the torque needed to break the other wheel free so bingo, I can pull out with at least 3 tires spinning and sometimes even get both fronts. (it seems easier to load up a drum brake)
It takes practice, but works pretty good.
Mike
Parking Brake cwsenn Jeep CJ Forum 0 06-13-2009 07:45 AM
Parking Brake??? cj71983 Jeep CJ Forum 5 11-08-2007 02:09 AM
A better parking brake? algmmech Jeep CJ Forum 9 09-25-2007 06:45 PM
!@#$'n parking brake Ezredcj Jeep CJ Forum 3 12-04-2005 05:37 PM
Parking brake djfuzzy Jeep CJ Forum 5 07-19-2004 03:57 PM
